I have just purchased a Kenmore Elite Trio model no. 795.77549600 manufactured in 2007 and have no books with it. Can I get an operational book for this refrigerator.
Is the full model number 596.76582600? The three-digit prefix indicates the actual manufacturer of the fridge with the Kenmore label. The manual covers a large number of Kenmore refrigerators. The water filter is only in select models. The 596.76582600 does not have a filter. The entire set of parts diagrams are available here: https://www.searspartsdirect.com/model/14cl4yks2t-000583/kenmore-elite-59676582600-bottom-mount-refrigerator-parts . The only filter listed is a refrigerant line filter for the coolant system.
You will put it in the bottom of the tub, before adding the clothes. Please do not put it in you dispenser, it was not designed for this. Hope This Helped MERRY CHRISTMAS, Tim
if line is for the ice maker, with water on loosen fitting on end of line where it is connected to fridge(hold towel under fitting) and re tighten after you see water seeping out.
press the helpful button
I was going to explain a device called a "defrost timer", but I did a search on your fridge and found the following important information for you to check on FIRST!
Try going on the manufacturers website, look for support, and software or drivers download. You'll have to enter the make and model number, but you should be able to get the necessary software for operation.
Try putting ice inside instead. if the machine gives you water then it's converting in reverse order.& still working. put the machine upright & youi'll get ice...
This is a refrigerator manufactured by LG and is well known for this type of malfunction. There should be two 1/4 inch screws on the outside of the freezer drawer tracks near the front that will allow you to pull out the entire door assembly. Once this is done and the unit is fully defrosted and unplugged, there are a couple/few screws in the back freezer panel. Once the panel is removed, this part is located on the upper right side of the evaperator coils. It is sometimes wedged in tigtly but should pull out with a good tug. Unplug the white harness, remove defective part and reverse this process. Good luck and happy shopping for the shoes.
