Question about Brother HL 5250DN Laser Printer
Black stripes down paper
I continue to get black stripes down the center of the paper when printing a document. How do I get rid of these?
    President:
  • 2,306 Answers
You remove the drum/toner cartridge and run the blue tab on top back and forth several times then blow out the slot with canned air, while it's out you reach inside with a soft cloth and wipe the narrow window above where the drum sits, open the back door and shine a light inside to see if the lines are on the fuser roller, if there you will need a new fuser.
Posted on Feb 01, 2010
  • Brother Master
  • 344 Answers
Try this fix:
Posted on Aug 23, 2019
6ya staff
SOURCE:
On Epson Artisan 800 the scanner leaves wide black stripes for the whole length of the paper. Printing From a file is OK.
If computer printing is fine (source) but scanner printing has problems, then of course, your problem is in the scanner. The only solution based on your info (which is good), are the lines in the same areas on other bad scanning prints? If so, your problem means that the scan-head has a connection problem leaving a 'black' send to the print buffer. This will require some technical repair replace or clean connection. Remember that this is a mechanical movement that not only records what it 'sees'e but at what X-Y location the read was 'seen'. It would be worth it to get an estimate from your local computer repair center give you an estimate.
Sep 22, 2014 | Epson Artisan 800 All-In-One InkJet...
Black stripe running down left side of paper when
Open the top of the fax where your documents go in. There will be a thin **** of glass where the document is read. On the end that reads "dirty" is a smudge or some white-out that needs to be cleaned. You may have to clean it with some cloth wrapped on a flat tool. Do not scrap or scratch anything, just clean enough to get the dirt off. Then make a test copy.
Apr 29, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Re: Canon Pima MP500 Printer.Despite running cleaning settings for print head and rollers ectc,I am still getting a 1cm wide line of black ink through the length of the reverse side of printed pages....
On back side of printed paper?
It means that you have an ink in paper path, i would ques on registration roller (long black roller which you can see when you open the printer cover).
Try to print 20-30 white sheets or similar to get rid of stripes
Jan 18, 2010 | Canon Pixma MP500 All-In-One InkJet...
Black bar printed in the center of copied document
try copying the document to your computer and then from computer take a print out.
Aug 23, 2009 | HP Photosmart 2575 All-In-One InkJet...
Light lines down middle when printing black
try to clean the class of the machine, if its still there, this means the black drum is scratched since its fine with other colors, to test it very good open the document feeder(put it up) and hit start buttom(without putting anypaper on class), black paper will come out, check if the line there, if yeah, change the black drum.
let me know wat happen Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Apr 24, 2009 | Samsung CLX 3160fn All-In-One Printer
Pale vertical stripe on black prints
It sounds like the black drum unit needs to be replaced.
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
MP830 prints a black stripe down the back of the paper
the waste ink pads are full ..when the black line appears it is an indicator that the waste ink pads are full it is usualy because the printer has reached its life expectancy the solution is either buy a new printer or pay a tech about 170 dollars to repair it
Jan 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Black mark on printed copies
Remove the black drum and see if see the line on the drum that you see on the paper---if it is replace the drum unit.. Good Luck
Aug 26, 2008 | Ricoh CL4000DN Laser Printer
PAPER PRINTING OUT WITH BLACK LINES AND MARKS
When coping I have a black line down the left side of the page. This only happens when I'm copying NOT when I'm printing off a document from Word or the Internet on my computer. How can I get rid of this black line?
Aug 14, 2008 | Office Equipment & Supplies
Dark strip down center of page when coping from tray
There is a small strip of glass on the left side directly under the edge of the scanner, About a half an inch wide. It has something on it.
May be very hard to see, use a strong glass cleaner or some alcohol and a regular piece of paper to clean it with.
May 08, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Brother HL 5250DN Laser Printer Logo
494 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
