Before you worry about where to get parts,you need to know what is wrong and what parts you will need. When a compressor does not run but the fan motor does, then either the compessor is bad (in which case you need refrigeration expertise) or the starter components have failed ( in which case you can replace. The two most common failed parts are the start relay or the overload (both attached to the compressor. Goodluck, Macgivor
