On timer blinks tv not turn ON I did try to unplugh plug back but still not working please advise
Mine has the same problem, but unpluging it did not help.
Any other solutions?
Well, it sounds like the TV is in timer standby mode and thus preventing the TV to turn on or off.
Regards,
SOURCE: jvc tv av-32d502 timer light is flashing will not turn on
Hello, I am a tv tech. I worked on a JVC AV-32D502 today. Problem: led flashes / no power or picture at all. Same as trobertson52's set. The microprocessor is bad in my machine. trobertson52, if your sets' relay does not click when the power button is depressed you most likely have the same problem or the standby power circuit is at fault. That circuit supplies +5 volts to the micro.
Edtal you have a different problem with your machine. Your machine is going into shutdown. A number of circuits could cause this and would need to be looked at by a technician to determine exactly which circuit is at fault. High voltage transformer (HOT) \ Vertical Circuit \ Power supply are the most likely causes.
barneyinNC
i have exactly the same problem with the green timer light blinking on and off. i have tried switching off at the mains for 5 minutes but it is still the same. please help.
Same problem as above according to the manual it is the on timer and can't turn it on
same problem...on timer blinking..tv does not power on...
on timer blinks but the tv will not turn on
push power button to turn on it turns on and the timer light flashes for a few seconds then the tv shuts off
