Download the epson plq20 adjustment program .iso file. if you are using windows7, run the program in compatibility mode. select languages and settings. after that select port,then select the option 4 and run. after executing 4 run option 6. Note: Hold the F1 and power on then execute the programDownload the epson plq20 adjustment program .iso file. if you are using windows7, run the program in compatibility mode. select languages and settings. after that select port,then select the option 4 and run. after executing 4 run option 6.
You can't post conmments that contain an email address.
I Have A Epson PLQ-20 passbook Printer and it is connected through USB cable. after successful setup when i give print command to the printer it is not responding and nothing happened.
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
I need to reset Logic Card and Firmware of PLQ-20 printer.
