I have a sony sxrd 50" tv and triying to replace the lamp. when triying to teke the lamp out it just won't, it gets stuck and already remove the screw holding it in... it also has a hinge the you supost to pull up to remove the lamp but stii gets stuck.. is there someone that can help me that had the same problem before when removing the lamp out of tv.. I will chek back later today for help,, i will apreciate... thanks
SOURCE: How to replace lamp in Sony Wega KF60XBR800
Here's the instruction.
http://www.911phone.net/Sony%20XL-2000%20A1601-753-A_Instruction_Manual%5b2%5d.pdf
SOURCE: Lamp Replacement on Sony Wega TV
Please explain the location of the lamp for a sony kf-50we610 50 inch tv. Note same problem as above.
SOURCE: Sxrd 50 won't turn on - Cooling system or dlp lamp?
4 blinks is a fan error, check and see if the fans are clogged with dirt. Unplug the set then take the back off and get some canned air and blow the fans out.
Testimonial: "Freakin' awesome. I was quoted $250 - 500 to fix this 'mystery' issue. $6 at office depot and it's fixed! You Da Woman TVTECHLADY!"
SOURCE: RESET LAMP HOURS ON SONY KDS-R50XBR1 sxrd tv
Click here to download the user'e guide and go to page #113 to reset the TV to factory settings.
