Immediately after I turn the power on. This is over-current protect.
Perform the following steps
(1)Plug your amp to AC outlet.
(2)Switch it on.
(3)observe time taken for switching off.
(4)immediate to shut down over current protect
(5)3 seconds to shut down DC protect.
If over-current protect do the
following steps
(O)unplug the amp.
(1)download NR806 service manual.
(2)open the amp metal cover.
(3)measure 7 large white resistors resistance loacated next to power transistors mounted on a large heat sink with black probe touching the middle pin and red probe to first/left or third/right pin.
(4)If this 3 Pins large white colour 0.22ohm x 2 resistor is open with infinity ohms ,
(5)replace it and jot down this channel for example left surround faulty. Usually only 1 channel went faulty.
(6)the two large power transistors next to this white resistor 0.22 ohms x2 should also be replaced.
(7)plug the amp
(8)switch it on
(9)if ok, troubleshooting get done
(10)if not ok
(11)replace ALL the components of this power amp channel.
(12)pre-amp section no need to check.
remember if not OK, the replaced 0.22ohm x 2 resistor and 2 power transistors maybe shorted again. Check them first. If OK, replace ALL Components in this channel except 0.22 ohm x 2 and 2 transistors. 0.22 ohm x 2 means left and middle pin 0.22 ohm as well as right and middle pin also 0.22 ohm that are 2 pieces of resistors with 0.22 ohm in a large white 3 pins resistor.
Remember sometimes the
0.22 ohm white resistor is normal. If so, use a digital multimeter to measure the be bias transistor voltage via multimeter diode test function. You can compare the normal value,580mV to 650mV with faulty one,3.2mV. And the CE resistance is 1.8ohms only instead of 3 Mega ohms.
immediately after I turn the power on. This is over-current protect.
(2)Switch it on.
following steps
(O)unplug the amp.
(7)plug the amp
(8)switch it on
(10)if not ok
Open and blow clean the insides and try. had worked for me.
SOURCE: HT-S580 Randomly Shuts-Off
Most systems like this have what is commonly called 'protect' mode. This usually kicks in when the volume is at a very high level, and the unit tries to use more power than its designed for, or it is overheating. The reason why only this connection has problems and others do not could be a few reasons. One, satellite signals usually carry high quality digital sound, and use more power to play sounds that may be inaudible. Two, You may also want to upgrade your composite cables to the highest possible quality. (There are many durable gold plated models that work well). Low quality cables could hasten your problem and produce signal bleed. In addition to this, the unit may cut power when it overheats. Make sure the vents on the unit are not obstructed, and that it is not near other components that are generating heat.
SOURCE: Onkyo HT-R501 7.1 reciever issues
you have to get it fixed. same thing happened to my onkyo reciever and they said it was a bad circuit. had to take it to an onkyo tech and have it replaced.
SOURCE: onkyo HT-R500 amplifier protection circuitry activated
u have a short.
remove all speakers cables and turn it on, if remains on and u can up the volume do the next.
1: turn it off.
2: connect only 1 speaker cable (each time to see if the short is in one speaker or cable)
3: turn it on, up the volume.
this way u must be able to see what cable or speaker have the problem.
if still the same prob the short is inside.
i put a answer of a prob where cant up of 41 check the cleaning method.
Good luck
SOURCE: Onkyo HT-SR800 won't turn on
If you call Onkyo directly, 201-785-2600, there is a procedure to "reset" the system, something like holding the power button on and holding down another button for a few seconds. Can't remember which, so I can't be sure, but try giving them a call.
SOURCE: My Onkyo HT-R510 will shut down after several
Might be over heating. Make sure you don't have anything sitting directly on top of it. I even put a little fan blowing outward at the back of my system to keep it cool.
