Hi, where is the CMOS battery located?
I replaced small battery under the modem, but problem is not solved.
What is happend? Always after shutting down and turning on, evrything appears, like first turn on. Does not remember any set ups.
So I replaced small lithium 3volt battery under modem. But the problem was not solved. Now I think, mait be this was not the CMOS battery.Is this the CMOS battery?
Thanks, Marian
Disconnect the power cable from the computer and remove the battery pack from the computer.
Close the screen and turn the computer upside-down. Locate
the modem/combo card compartment on the right side of the computer
(adjacent to the modem/telephone and network cable ports).
Read more: How to Remove a Compaq Armada M700 CMOS Battery ' eHow.com http://www.ehow.com/how_8291166_remove-armada-m700-cmos-battery.html#ixzz2BpnFjqxN
Read more: How to Remove a Compaq Armada M700 CMOS Battery ' eHow.com http://www.ehow.com/how_8291166_remove-armada-m700-cmos-battery.html#ixzz2BpnAs3op
Remove the two screws on the modem/combo card compartment cover and take the cover off.
Remove the modem/combo card from the compartment, disconnect the cables and set the card aside. The CMOS battery is now visible.
(http://www.zlectronic.com/crms/bigpic/stock/zachshop/300_399/33653_4_z.jpg)
Read more: How to Remove a Compaq Armada M700 CMOS Battery ' eHow.com http://www.ehow.com/how_8291166_remove-armada-m700-cmos-battery.html#ixzz2BpnMuM4A
Disconnect the CMOS battery cable from its connector and remove the battery from the compartment.
Read more: How to Remove a Compaq Armada M700 CMOS Battery ' eHow.com http://www.ehow.com/how_8291166_remove-armada-m700-cmos-battery.html#ixzz2BpnQBxYI
Replace the CMOS battery, and reassemble the laptop by performing the previous steps in reverse order.
Yes that was the cmos battery, I'll see if I can find a better solution for this issue for you.
Most people will notice the cmos batter is flat when they receive an error during post just after turning the pc on. This is a warning tell you the settings were lost, replacing the battery will not put them back. After replacing the battery go into bios by pressing delete/f2/f10 as instructed by your bios, choose the 'load defaults' option, then set the time and day, then 'save and exit'
KaytonK
Please Oh Please I Begging You!!! I Have Got An Acer Aspire 5720 Laptop & I Looking For The CMOS Battery BUT I CANT OPEN THE LAPTOP UP! Help Me Please I Not Happy Im Going Off My Head Its Doing My Sweeding :( <<<<<---- Look! xxxxxxxxxxxxxxxxx
You will find the CMOS battrey under the modem. Turn laptop up side down, it is in left, lower corner. Battrey you can buy in any electrinic shop, but dont go by laptop name, go by battrey number. It cost 5.00$
Good luck, Marian.
I just replaced the CMOS battery on my Gateway laptop and am still getting checksum bad - defaults loaded message.
Hi where did i find a cmos battery of compaq armada m700, i think it is low bat because it always back to earlier date and time when i open my laptop, hhow can i replace a new one?
thanks
it me henry
The CMOC battery is rechargeable, it will take time to reach full charge. It is being charged while the laptop is under charge, but may take a few hours. However, if the charging circuit is gone there is a whole other problem, a replacement of that is a bit harder. Check the main battery as well, by going into the Display Properties, screen saver and hit the power button. Run the calibration on the main battery to see how well it does. In most cases when one goes down the other is not far behind.
Good luck,
Derick B.
[email protected]
I have replaced the cmos battery and about 3 weeks latter had the same problem again
Hi, after replacing CMOC battery, the problem appears not besolved. But next day, I dont know what happend, computer is now working properly. Marian.
Where is the CMOS battery
hi my name is jay and my cmos battery is dead and there is a battery under the other battery and the battery under the modem do you know which one it is, thank you
