There is a small panel on the bottom left front of the washer with a tab on the top middle holding it onto the front of the washer. depress this tab with a small flathead screwdriver and the panel will open downward. You will now see a small round black piece on the left with a flat screw head on it, about an inch in diameter. unscrew this about a quarter of a turn and it will come out with a small hose attached. This is connected to the drain pump. Have a shop vac ready, pull the black plug out of the hose and this will drain the pump. The larger round piece on the right, about 3 inches in diameter is your drain pump. After draining all the water unscrew it with your hand. When you get this out it will have a screen attached which needs to be cleaned at least once a year.
Please rate this post. Thank You.
