Frigidaire FRS26H5AS Side by Side Refrigerator Logo
Harold Hinton Posted on Jan 22, 2010
My icemaker works slow to make ice. Sears Kenmore side by side refrigerator. Model.57572791
Anonymous
Level 1:
New Friend:
  • Contributor 40 Answers
  • Posted on Jan 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
40
Questions
0
Helped
7401
Points
56
Check temperature in freezer compartment,needs to be near zero,if it is,there may be a problem with the internal thermostat on the icemaker,also checkthat the icemaker mold is filling completely with water,all the cavities should fill
Looking for a free owners manual download for a kenmore cold spot model#106.50442902. Can't get ice maker to work...water goes through d ispenser......?
A copy of your owners manual can be found here.
10650442902 KENMORE ELITE SIDE BY SIDE REFRIGERATOR Manual Sears...
Although I would say there is probably nothing in this that will solve the icemaker not working. This is a complicated unit and there are several different things that can cause the icemaker to stop working!
First thing to check is that it is not jammed.. Lift the cover and make sure a cube is not stuck in there.
Water slow in door & icemaker not making ice? Whirlpool frig. & freezer side by side
Check out the water source to the refrigerator. Re the icemaker - is there water in tray? If so you need a new heater assembly. No ice? - then the water solenoid is not working.
Search Over 2 1 Million Appliance Parts
Sears Online In Store Shopping Appliances Clothing More
I have a sears model 10659592990 refrigerator ice maker stop working
it will be either no water into mold , freezer too warm, no power to icemaker, or if it is the style with the control module on front could be module
Icemaker leaks after refilling causing ice cubes to weld into a mass of ice.
I believe your water control valve on the back of refrigerator is leaking slowly and causing this. They are called dual water control valves because the ice maker work on one side and the water dispenser works on the other side. Most ice makers open the water valve forthe ice maker for 7.5 seconds just long enough to fill. Do you have your Sears model numer for example 321.54689 somewhere on your refrigerator or around door frame. Sea Breeze
2helpful
Kenmore icemaker does not work
Hand drawn of the GE # WR30X1009 found in 10-12 yr old Kenmore/sears/GE side by side refers. Couldn't find one ANYWHERE so forgive the hand drawn. Mine would not eject ice, intermintant. Bad microswitch on the on/off/vacation mode between the normally open side.
Kenmore 106.53342300-side by side-icemaker not working..at all
IT COULD BE 2 PROBLEMS
1 .YOUR DEFROST TIMER IS BAD.
2. YOUR WATER INLET VALVE IN THE BACK COULD BE BAD.
BOTH PARTS ARE VERY INEXSPENSIVE(USUALLY UNDER 20 BUCKS AND YOU CAN GET FROM YOUR LOCAL SEARS OR ANY WHERE ON LINE. GLAD TO BE OF SERVICE
Kenmore Side By Side Refrigrator ICe Make Not working
Is the icemaker producing ice and it's just not coming through the door? Or is the icemaker not even producing ice???
there is valve for each right at the water inlet, your valve is stuck or your coil is bad......get a new valve.
19helpful
2answers
Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
