Re: I have and RCA RCR311ST Universal Rmote Contro which...
I can help you reprogram your RCA RCR311ST for all your Orion TV. The folks at RCA did away with a code search button for this model and you must press a combination of buttons to setup programming more.
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
okay this is what you do hit the code search botton hit the tv botton the hit channal up untell you find that your tv is changing channals then hit tv again and that should work just do it slow becouse if you pass the channal it changes then you will have to use the channal back button tell it pops up again it will work.
I have the same TV.
I called RCA and they said the remote is not 'code compatible' and that
I should check back with the website in the future. I think a learning remote is the only option at this point. Maybe a Logitech Harmony?
Code For Model RCR311S
Code 1003 for Panasonic TV
Code 1054 for Panasonic TV
Code 1062 for Panasonic TV
Code 1109 for Panasonic TV
Code 1170 for Panasonic TV
Code 1248 for Panasonic TV
GOOD LUCK THESE ARE THE CODES LISTED FOR YOUR REMOTE/
I programmed an rca universal remote by:
TURN ONTHE TV
HOLDING DOWN THE TV ANDTHEON/OFF BUTTON ATTHE SAME TIME.UNTILTHEON/OFF BUTTON STAYED ILLUMINATED.
PRESS THE PLAYBUTTON IT WILL BLINK,IF TV DOES NOT GO OFF PRESS PLAY EVERY 5 SECONDS UNTIL TV GOES OFF.
ONCE TV TURNS OFF HIT THE REVERSE BUTTON THE TV WILL COME BACK ON.
HIT THE STOP BUTTON TO SAVE THE CODE.
REPEAT THIS BUT HOLD THE OTHER DESIRED DEVICE INSTEAD OF THE TV.
HOPE IT WORKS
Igotthisinfo from google....then typed in rca universal remote...there was a sight for programming remote.
