It is common for binoculars to have one independently focusable eyepiece. If one eyepiece can be rotated, then that is the case.
If that is the case, focus through the one that DOES NOT rotate using the center control until you get a sharp image on that side. Then rotate the eyepiece on the blurry side until the blurry side is sharp. If you succeed at this, from henceforth the center control will focus both eyes adequately
Most binoculars should allow you to grip the two sides and pull them closer together to fit the distance between your eyes.. Have you tried this? What you should see is the two images come together to form one.
If you have tried this already and you still get the two images then it's possible the model is just too wide for your eyes.. If they're new you could try return them for another type that fit better..
If this works for you then here are the instructions for setting up the binoculars to give you the best result for your eyesight..
This is more common than you would think.. Here's how to set up a pair of binoculars to suit yourself. Any good binocular will be able to do this and the reason is to allow you to adjust them for the difference in strenght between your two eyes. I wear glasses myself and sometimes contact lenses so it's good to be able to quickly adjust them.
1. turn the binoculars over so you are looking at the underside. 2. on the eyepieces can you see on one eye(usually the right eye) a little plus - minus marking. The eyepiece should be able to rotate a little to each side of this marking. 3. Set the rotating eyepiece to the middle setting. 4. Look through the binoculars as normal and bring the two sides together until you form the two circles that you see into one. 5. Pick an object app 10 meters away. 6 Presuming that the adjustable eyepiece is on the right hand side then close your right eye, look at the middle distance object you chose with your left eye and use the central focusing knob/wheel in the middle to bring your left eyepiece into focus. 7. Now, close your left eye and adjust the rotating right hand eyepiece while looking at the same object until your right eyepiece is in focus. 8. The binoculars should now be set for the differences in strenght of your eyes and you can use the middle focus control as normal.
Most binoculars have a soft rubber eyepiece that can be folded back for people who wear glasses but I, like most people I know who wear glasses, find it horribly uncomfortable.
This method allows you to set them for yourself and if someone else uses your binoculars you can quickly reset them for you.
Hope this helps...
- Oh yeah, sorry, forgot to mention.. This set up is so you can use them without wearing your glasses.. Much more comfortable!!
Go onto the www.Sharperimage.com web site if you look it will tell you that Sharperimage are in receivership but they do point you in the direction of a support comapny called N.E.W.
In reality you should be able to buy those leads from any decent camera shop or a place like Tandy
Bausch & Lomb was purchased by Bushnell in the 70's. Your elites are Japanese made and considered quite a good binocular. Bushnell continued to make the same binoculars bearing the Elite name but replaced B&L with Bushnell. The current elites are different shaped. You could contact Bushnell or you could go to a store in your area that may stock the older Bushnell Elites and try and see if the eyecups fit.
