I am trying to print on A9 envelopes (5.75" x 8.75") to address the invitations to my wedding. I tried using the envelope printing tool, specifying the custom size of the envelope, and I get a size mismatch error. I think the problem stems from the feed method (as selected under Tools/Envelope and Labels/Options/Printing Options). The default feed method is to have the envelope centered in the feed tray. However, since the width of the envelope is less than that of a sheet of paper, I need to use the paper feed guide which pushes the envelope to the right of the printer feed tray. When I select this option, I get a warning that I am deviating from the default settings and that these settings may be incorrect. When I try to print anyway, I get the mismatch error. I am at my wit's end and would appreciate a solution (please be very detailed in your reply...) Thanks!!
Set the envelope size in the printer properties paper size list to A5 (5.83 x 8.27) which is only .08 inches wider than the short side of an A9 envelope (5.75 inches). The paper size sensor on the HP6520 printer must not be sensitive enough to tell the difference. I can print A9 envelopes just fine using the A5 setting.
SOURCE: Letter size envelope does not fit into the paper holding tray
Hi cmwww920,
Usually letter envelopes are insert long-way into your printer. I recommend using the Microsoft Word envelope wizard to print Sender and/or Recipient addresses on envelopes. Here's how it works:
1) Launch Microsoft Word.
2) Click Tools > Letters and Mailings > Envelopes and Labels...
3) Type in what you want to see on the envelope.
4) The default feed direction is shown in the lower right corner of the dialog box. To change it, click Options and select the Printing Options tab. Adjust the settings as you please.
5) Click OK to exit the Options Dialog Box
6) Click Print (in the upper right corner of the "Envelopes and Labels" dialog box.
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
SOURCE: envelopes
Follow this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu03053&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
SOURCE: HP Photosmart 6150 AIO
Sounds like it might be the same problem I had on my HP C7180. It seems to be rampant throughout their Multifunction printers.
My Fix, combining several others:
1. Go to Printers and Faxes on your Start Menu. In the Printers window, select Server Properties from the File menu. Use the Forms tab of the Print Server Properties dialog box to view printer forms. You may also see lots of forms that you wish your printer could see, but don't worry, it'll see the one you create now. And be sure when you create your form that you use the narrower dimension for the width and the longer dimension for the height. Usually for envelopes you will print in landscape mode.
2. Select the Create A New Form check box.
3. Enter a new name for the Form in the Form Description For field.
4. Use the fields in the Measurements area to set the paper size and margins. *Use the narrower dimension for the width and the longer dimension for the height*.
5. Choose the Save Form button to save the form. The Save Form button only gets pick-able when you type in a different name than what's there already.
Now go to your document program, such as Word. Make sure the window for the document you want to print is the active window. Select File/Page Setup..., Paper Size Tab, and there select the form you just created from the dropdown list
Still in your document program, select File/Print... then Properties. Select the Features tab, which may be differently named. Under Resizing Options/Size dropdown, select More... and there you'll find your newly created form down at the bottom, under Custom. Pick it.
If you're printing envelopes or other things where the way you view it it's wider side-to-side than it is tall, be sure and select "landscape" in both "page setup..." on your document program and in File/Print.../Properties/Features?Basic Options.
When I did all this methodically, I was able to print my Christmas envelopes. Yay!
SOURCE: Paper jam when trying to print envelopes.
You need to make sure that your print sriver setting match the setting on the printer itself.
If setting are changed on the printer itself to envelopes then when you go to print click preferences button on print screen and look for a place to change paper type (usually defaulted to letter size.) Change paper type to envelpoes and click ok. Click ok again on print screen and it should print correctly.
Paper types must be configured the same on the device as well as the print driver installed on the computer.
Hope this helps
TankMurdock
SOURCE: Printing Envelopes
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print.
The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11.
I hope this helps.
Deny
