1. Are you trying to receive off-the-air broadcasting? If so, you'll need a digital converter box. This set doesn't have a digital tuner, so there won't be any channels for it to receive without the converter.
2. Are you connecting a cable from a cable converter box, satellite receiver or FiOS set-top box? Your TV will need to be set to channel 3 or 4 to see the signal from the device.
3. Make sure the center wire in the plug on the end of the cable isn't bent over, and that it extends far enough (about 1/8 to 1/4-inch) to make a good connection.
4. Do you know for sure that the cable you are connecting is working? Is there actually a signal on the cable? It may be disconnected somewhere else (at a splitter, for instance) or there may not be any signal source.
5. Have you tried another TV to test the cable? If the cable works with another set, the tuner or antenna connector on the snowy set may be bad. If the cable connector is tightened too much when hooking it to the TV, the connector may be damaged and this can cause the snow.
Start by checking with a known good TV. If that one is snowy, you can check the other possibilities. If it works, you'll know the problem is in your set and can decide what to do (repair or replace).
If you can first connect the Fios box via component and that will rectify the issue and still allow HD. HDMI is funny, if there is anykind of communication issues between the TV or the Fios box you see what happens. You might also call Samsung to see if there is ANY firmware/software updated for your TV specifically to fix such an issue with the Fios/Mortorola connection. If there isn't then the issue is the cable box since the TV works ok on HDMI with other devices.
when the screen becomes snowy, it means that something in the cable box is being overheated. what you should do is take a small desk fan and hold it beside the cable box. this has happened many times when my family has played on their xbox 360, and the desk fan solved this problem. i hope that this helps!
If you are on cable, first run the cable wire from the wall directly to the TV, eliminating any cable box and/or VCR. If channel 2 is snowy but the rest (especially 3-6) are clear, it is most certainly a cable problem and not a TV problem. The TV uses the exact same circuits for channel 2 to 6 (VHF-LOW) so if the tuner was bad and 2 was snowy, 3, 4, 5 and 6 would be snowy too. Bring a second TV into that room, disconnect the cable wire from the RCA and connect it to the second TV. Is channel 2 on the second TV as snowy as it was on the RCA?
the best option for you is to put another (small) TV instead of plasma to check whether your cable is OK.
If you need more info please advice.
Arpi
