Braun ET66 Calculator Logo
Posted on Feb 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Battery Change I have three Braun ET66 calculators and I tried changing the batteries in each this past weekend. For each, once I pulled the battery and replaced it, the calculator would no longer power on. I tried multiple replacement batteries and had the batteries checked and they were good. What is really odd is that one of the calculators was brand new. Thanks, John
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 10, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
208
Points
Hi, i have the same problem with mine, did you manage to work out a solution?
arobb
Level 1:
  • Posted on Dec 01, 2008
arobb
Contributor
Level 1:
Answers
Questions
0
Helped
208
Points
Hi John
I have had an ET66 in the past but lost it. Would you sell one of yours?
Thanks
Alan [email protected]
Anonymous
Level 1:
  • Posted on Mar 03, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
208
Points
Hi John
Can't help you with your query but I would be grateful if you could help point me in the direction of where I might be able to buy a Braun ET66
Regards
Mike
Anonymous
Level 2:
  • Expert 77 Answers
  • Posted on Feb 11, 2008
Anonymous
Expert
Level 2:
Answers
77
Questions
Helped
28836
Points
135
Could be a manufacturers flaw.see if you can exchange them
Braun contour 5790 battery replacement
try this link: http://www.braun.com/us/male-grooming/maintenance.html
When I press ON, my calculator screen displays a couple random numbers and letters scattered across the screen, including a solid vertical line in the upper right corner. As soon as I push any key, the...
There are three possible solutions here. From what you are describing to me, you say the screen displays a couple of random numbers and letters, including a solid vertical line in the upper right corner, are scattered across the screen? Sounds like you are still in graphing mode. There is nothing wrong with your batteries and changing them won't help because I already know that you didn't change the CR Lithium Battery. This is the "memory card" for the TI-83 Plus. If you don't change that, when you insert new AAA batteries in the calculator, the memory has not been deleted. You probably don't remember, but the calculator remembers the last problem that you did, which was a graphing calculation. Try pressing the "Graph" button and the calculator will go back to function mode. If this doesn't work, try resetting all the memory.
  1. Remove a battery from the battery bay.
  2. Press and hold the CLEAR button while re-installing the battery.
  3. While still pressing the CLEAR key, press and hold down the ON button. If the home screen displays, release the keys.
  4. If the home screen is displayed, press 2nd MEMto display the memory menu.
  5. Select 7:Reset to display the "RAM ARCHIVE ALL" menu.
  6. Press the right arrow twice to display the "ALL" menu.
  7. Select 1:All Memory to display the "RESET MEMORY" menu.
  8. To proceed with the reset, select 2:Reset. The message "MEM cleared" is displayed on the home screen.
If this doesn't work, try changing the CR Lithium Battery. It is located in the battery bay at the top with the cross-head screw in it (It says BACK-UP BATTERY). It tells you what type of battery it takes and how to insert them in. I hope these possible solutions help. If all of them don't, then the only other thing I can think of is that it has some internal part alignment issues or a cold soldering iron blob, on the inside of the calculator. I saw one time on the Internet that cold soldering irons can sometimes make electronics not work properly.
1helpful
How do you change the battery on a ti-84 plus calculator
Turn the calculator over. About in the middle of the back of the calculator, there's a latch. It's above the mainly rectangular battery cover. Push the latch down toward the rounded end of the calculator and then pull the cover out toward you. The batteries are underneath.
If you need to change the backup battery, use a small screwdriver to remove the screw under the battery cover.
HOW TO CHANGE A BATTERY IN EP 100 BRAUN BEARD TRIMMER
mcdevito75 here, You may or may not be able to change the battery--ies some batteries are attached to a circuit board. refer online to Braun.com Battery replacement and, you"ll most likely need special screwdriver to change the battery--ies.
Changed battery but still displaying low battery and the dot is not displaying
Hello :
Try to change the battery once again . If that didn't help , then I would guess that the base where the battery sets is rusty or dirty . Try to clean it . If that didn't help also , then try to reset your calculator .
I hope that will help .
please rate !
4helpful
Change the battery
use a small flat screwdriver to gently pry off the plastic cap that surounds the AC port. once removed, the side grips will pull off revealing 4 screws on the back. remove screws to seperate front and back case and get to the insides. batteries van be purchased at shaveroutlet.com
Battery
Energizer Silver Oxide 1.5V Watch Battery - EVR357-303TS http://www.batteriesplus.com/products/45-0/3973-Calculator-Batteries/305216-Braun/4776-(ET66)/1.aspx
Good Luck! Don't forget to come back and rate my solution for you.
- Jim
2answers
Ti-83 plus
try changing the back up battery also. This generally helps. The next time you change your batteries, change them one at a time. don't take them all out at once. This won't happen if you do it like that.
Braun 6520 shaver stops working after one use on batteries
dear sir, i have one like yours,your shaver need to change the battery.
Top Braun Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Braun Office Equipment and Supply Expert? Answer questions, earn points and help others
