Refrigerators Logo
Anonymous Posted on Jan 17, 2010
Keeps beeping? my ge refridgerator keeps beeping every 60 seconds. sounds like it is coming from the back not inside or from the front panel
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1253
Points
For $19.95 I will tell you how i solved this problem. thanks for nothing fix ya
Refridgerator beeps
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
I have a ge profile refrigerator and it works fen except it ekes buzzing. The ice lock/lock function, no body is pressing the button but it keeps locking and unlocking itself and the buzzing/beeping i
The switch that does the lock/unlock has got wet inside.
Make sure you can see the back panel of the switch and use a hair dryer to warm the panel back and the front of the switch. When it gets warmer it may dry out and start working normally.
Sanyo beeps every 30 seconds
Any timer working? Any keys on the remote are jammed? Do you get the same problem even when you use some other input like a DVD player?
1helpful
Makes a woodpecker type sound for a few seconds intermittently. Sound like its coming from the middle of the refridgerator.
on the top left inside your fridge side there is a motor that opens and closes a little vent coming from the freezer side. one of the gears may be broken.
9helpful
Cannot open alarm system to change battery
Push down on the tab at the top of the panel and open the front panel (Panel will say enter security code now). Put a slotted screwdriver in the top hole and depress to fold dowm the second door. Battery is inside the plastic case with two screws holding on the lid. The battery is a 6V 1.2AH battery
AlarmProfessor.com
My refrigerator turns on and off i hear clicking sound.the compressor dont stops and then after a few seconds it runs again
my parents have a ge refridgerator tfx27e that is not cooling as of this morning. we had repair place out and they said the compressor is bad. per his words, he tested it and said electric is going to the compressor, but when it tries to turn on, something inside is stopping it so it won't run, needs new compressor.
the issue is, this is in a custom kitchen and the fridge has wood paneling on the front and matches everything nicely. i'm afraid a new fridge will never work with the panels made for this one?
it it worth fixing? i'm also pretty handy, but the repair guy said it's a 5 hour job. advice?
read more: http://forum.appliancepartspros.com/refrigerator-freezer-repair/558327-ge-refridgerator-tfx27e-not-cooling-bad-compressor-help.html#ixzz3pttwtbob
2helpful
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
4helpful
2answers
My GE side by side refridgerator makes a "howling" sound. Any ideas?
the problem you are having is in the main control board. ge has had a problem with this part causing the fan motor to go into high and low speed which causes the howling noise. unfortunately it is a costly fix, around $125 for the part. if you are savy to changing this part it is a matter of unplgging about 5 connections and replugging them. the new board has an extra set of pin that nothing connects to. READ the instuctions and it is a simple fix, saving about $50-60 in labor costs.
Top Refrigerators Experts
vince
Johnny 1000
