My freezer is only cooling to a certain point. Food is soft, but very cold...just not frozen. What could be the problem? The digital control is set to five, but not freezing solid.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Most problems with lack of freezing in part of the freezer is a matter of overloading the freezer. Things get frozen in the freezer by the circulation of air. If the air gets blocked the food will not freeze, same thing occurs in the fresh foods section, if the air from the freezer is blocked to or from the freezer the fresh food side will not cool properly. Make sure in the freezer there is a path down the back of the freezer and up the front for air to circulate to and from the evaporator coils in the back.
Hope this helps
there is a little door between the freezer and the fresh food usually when that happens the motor on that door is bad and sticks open and allows the fresh food to get to cold since your freezer actually cools the fresh food side, sorry i cant tell you where it is on yours since they are are different, it will be where the cold air blows in the fresh food side and the part is not usually expensive and fairly easy to replace.
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
THE RED WARNING LIGHT KEEPS COMING ON AND I HAVE TO KEEP PRESSING THE FAST FREEZE BUTTON, THIS IS EVERY FEW DAYS. IF I DONT NOTICE ALL THE FOOD DEFROSTS!
HI thanks for your question. try turning the thermostat to a lower, number. and clean all the coils at the back by the compressor. it might be all you have to do/ thanks the appliance doc. please rate my answer. thanks.
Ice cream requires a significantly lower freezing point than other foods. Keep it near the blowers or coils in most freezers and you'll be OK. Turn up the freezer a bit, and if it is all the way then move it away from the wall a bit more
hope this helps!
