F/02
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
Testimonial: "Thank You so much for your help. The drain filter was clogged with small items from my general contractor husbands pants. THANK YOU!!!:)"
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however;
your whirlpool duet washer needs a reset to resolve the control lock problem.
Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset
the control. Please get back to me if you have any other questions.
Kevin
