My babylock esante's lcd touch screen is not calibrated correctly. It is off by about 1/2 inch and down to the right. It responds but only to the icon below what you want to do. This would not be a big deal except the start button is at the bottom left and has no icons below it so I can not make it start. I need to know how to recalibrate it.
Thanks,
My BabyLock Esante Ese working perfect, the screen bring all messages an the resolution is perfect, only when I toych the screen, don't response, I try to calibrate, but don't work for me, any help please?
Turn off machine. Hold in the 3 buttons above the needle. Turn machine on. Voila in screen calibration mode. Using touchpen carefully touch numbers 1-5 in order. repeat until you hear beeps. turn off machine. restart and your good to go.
When your BabyLock Esante ESi2 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the BabyLock Esante ESi2 LCD screen, or buy a new machine. BabyLock no longer stock this item direct, but there is an affordable replacement available....Check this Link
Yes, I have a solution for this problem. Your screen needs to be recalibrated and you can do it yourself. Don't you wish they would just tell you this stuff instead of charging you an arm and a leg? Here's what to do: Before turning on the machine, press the start/stop button, the reverse button, and the needle position button all at once with one hand (one finger on each button). Hold them down and turn on the machine. What will come up is a recalibration screen. You will see the numbers 1-5 with a little plus sign beside them. Find a small blunt object (I used the tip of a mechanical pencil with the lead in instead of out) and while holding the start/stop button, touch the plus sign beside 1-5 in numerical order. Then, turn the machine off and on again in the normal way. This should recalibrate the screen. Pass it along, people! This is something no one should have to pay for!
I fixed it. I saw another post that said how to recalibrate it. Thanks,
