Miele leak when switched on for wash, from filter unit front LHS bottom of machince
The leaks in a washing machine could be coming from many different places in the washer.
The first place you need to check is behind the washer, check the two fill hoses and the water mixing valve.
The next thing to do is to remove the front panel, set the washer on the regular cycle and turn it on to start filling.
Use
a drop light and check all the hoses under the washer as the washer is
filling. Make sure to keep your hands away from any moving parts.
If
the hoses are ok, check the pump for leaks. When the bearings in the
pump wear out, that is when the pump will get noisy and that could
cause your Maytag top load washing machine water leaks.
Another
place that the washer could leak water from, is the stem & seal on
the holding tank. When washer leaks water from the stem & seal, the
water leaks down the center of the transmission.
When the stem
& seal need to be replace, the tub bearing has to be replace at the
same time. This is an expensive repair if you have to pay someone to do
it. If you do it yourself it will cost you about $110
