Either you have overloaded the machine or else your spin speed was set on high, lower it down and it should not happen next time.Make sure there is nothing broken inside the tumble or the spinning area...
Testimonial: "That's what I needed to know, Thanks "
Whut filter,, u must remove debri from drain pump, remove bottom panel and check pump for debri, once clear run a hot cycle possibly a sanitize cycle if available on ur model, also check the drain line for any obstructions,,, also if necessary may have to sepearte innner and outer tubs to clean excess debri,, rear bearing issues in futurre possibly?
Yes, I won't do it again ! However, more important what do I do now. The drum is full of feathers. Obviously clean it out as good as I can but what about filters or other possibly stopped up areas? Should I call service to have the inside (not the drum) cleaned?
