Dryers Logo
Posted on Jan 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code F11
Keep getting error code F11
Anonymous
Level 2:
  • Expert 262 Answers
  • Posted on Jan 13, 2010
Anonymous
Expert
Level 2:
Answers
262
Questions
Helped
75270
Points
802
Not sure what machine you have?
F11 Error Code for Whirlpool Duet & Duet HT :
F11 is Serial Communication Error, communication between the central control and the motor control unit cannot be sent correctly.
Check all connectors at the motor control and the Main control, check the motor, check drive system for any worn or failed components.
This is the only F11 Error code I could find for a washer.
F11 code keeps coming up half way through the wash cycle how can I fix f11 code I have a dacor dishwasher
Model number usually helps but I don’t see anything under F11 error codes
1helpful
4answers
F11 code flashing-washer stops
hi!!!!
try to unplug it end then check the control timer if it is broken !!!!
or open it if you know and fix it may be the spring that pull back the pause botton
might be broken go check it?
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
if its a Kenmore model then this message says that the button control board has lost sight of the main control board , but its been my experience that this maybe able to be reset and it may never come back or it will not reset and the control board will need replaced (50/50)
cycling power may reset this
Jan 30, 2016 • Dryers
Cycle will not spin and drain properly near end of cycle. Keep getting F11 fail codes when I try resetting my kenmore elite HE 3t any suggestions?
Hi Shaun, I just found (and watched!) a good youtube video which may help with your problem regarding the F11 code, link follows below.
Trust this helps, best regards Alan
Troubleshooting and Repairing the F11 Error Code in Whirlpool Duet Washer
1helpful
F11 error code
I appreciate the post, dan moore!
From the information you have provided your Frigidaire range is displaying an "F11" error code. Typically, the "F11" error code stands for a shorted keypad. This could be a false error code and the best way to clear any false error codes is to disconnect power from the range for at least ten minutes. If you continue to get an "F11" error code you may need to replace your EOC (Electronic Oven Control), I would recommend having a professional technician come out to properly replace any electrical component to avoid personal injury. Hope this information is helpful to some degree. -Matt
I keep getting an f 11 error code? what seems to
F11 is the code for a communication error between the CCU and motor control unit.  sometimes just re-seating the connectors on the CCU cures it.  if not, odds are it is a faulty CCU and needs to be replaced.
1helpful
F11 flashing kenmore he washer
The F11 error code indicates a serial communication failure. This happens when the 2 main control boards are unable to communicate with each other. This is either caused by a loose wiring harness connection or one of the control boards is defective. Good luck and please rate FixYa!
1helpful
Kenmore Elite H3 error code F11
F11 is a serial communication error. It is recomended to check connections from the motor control unit to the ccu. We are looking for the blue wires that carry info from component to component. The ccu is on top under the cover positioned in back for older machines and front right for new machines. The mcu, motor control unit is behind the kick panel below the door and is front left usually.Again we want to unplug check for dark or crusty connections if not to carefully reseat the connection and not only the blue serial wires but power as well. Remember to first unplug the machine and while you work the machine can reset, 30 minutes is typical.
Keep getting f11 error on
Click on the following link for an explanation of the "F11" error code:
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
If you require additional assistance, please let me know. I hope this helps you.
Top Dryers Experts
john h
