LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
Posted on Jan 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an LE error code
I have an error code "LE" on my LG dishwasher (LDF6810ST). The manual doesn't reference this code. Any idea what it means?
Anonymous
Level 3:
  • Master 487 Answers
  • Posted on Jan 12, 2010
Anonymous
Master
Level 3:
Answers
487
Questions
Helped
222935
Points
1216
Yes it can mean serveral things. Please check this SITE this is the service manual for your dishwasher. You can get parts at www.sears.com
just find your model. Service manual should help you a lot
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2061
Points
Error code "LE" is "check motor"
  • Anonymous Jul 19, 2013
    what is error code 2h
2answers
How to fix lg dishwasher that has code le
I think you may be getting IE code which relates to water inlet problems. Either the water pressure is low or the inlet valve may not be working properly.
Refer page 21 in the user manual which can be dowloaded from this site
Product Support
But if it is LE code then see this page for suggested fix.
LG Help Product Support and Troubleshooting LG USA
Le error code
LE is "Leak Error" there is a sensor in the motor compartment that detects moisture. this code is activated when a leak is detected in the motor compartment. you will need lg to come repair it as it is a notoriously difficult thing to fix permanently.
IE error in the middle of washing it seems to stop and the motor sounds labored.
LE error code means the motor is resritcted or locked up. you can try to clean out the sump area but will most likely need to replace the Wash Motor
3helpful
Our dishwasher shows an LE error code when started. What is wrong.?
Le error is a motor error. either there is something lodged in the pump holding the blades or the motor itself needs to be replaced
3helpful
2answers
LE on display
I just had my LG dishwasher fixed. I told the repair man that LE light was comming on. Even over the phone the repairman said its probably broken wires on the door. Me being in construction for years looked around the door for wires. Anyway the repairman took off 6 screws around the door, took the cover off. You will see about 50 wires taped together. He pulled them aside and visually checked them one by one. Sure enough two were broken in two. He twisted them together put tape and he was gone. $87.50 Still Working!
I have an LG dishwasher model 6810ST that comes up
LE means ( Motor error ) Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.
You'll have to disassemble the unit and make sure nothing is stuck in the pump or locking the blade.
Otherwise you may have a loose wiring connector
I'm getting a code "LE".
LE IS A LOCKED MOTOR CODE CHECK FOR OBJECTS IN PUMP BUT THE HAD THAT PROBLEM IS THE PAST
1helpful
Im getting error code "LE" on my lg dishwasher
While LE is the LG error code for "Motor Error": The Motor is working abnormally, it does not always mean that the motor itself has failed.
As you replaced the pump motor, are you certain that the Impeller of Washing Pump is turning freely? Next, is the Blade spinning freely?
If everything above is obviously not locked, the next item is the controller board. (PCB)
Hope that helps. Please report back with your findings! Good Luck.
1helpful
3answers
Error code LE
Hello and welcome,
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
1helpful
LG dishwasher
L2 error code is the same as an LE error code.  You have a problem with the sump motor assembly and needs to be addressed by a qualified LG technician.
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
