Replace your washer fill valve. You will need to remove the three to four screws in back, holding the top of the washer on. Slide the top panel toward the rear and lift the lid off. You can now easily access your fill valve. This is what your hot and cold hoses connect to. You need a complete model number to order the water valve. Good Luck, Appliance Specialists
Most likley your water inlet valve is cloged and stuck open. you will need to replace the valve.
