SOURCE: need to remove drawer from
There are two ways this drawer is held in place;
If you need further assistance, let me know
Regards;
reg501
The FixYa Team.....
SOURCE: Whirlpool Duet GHW9150P, Screws for Pedestals
You can go near hardware if nothing stock you may go to washing machine junk shop you can select any part as you wish.
SOURCE: Drops of water inside pedestal of washer.
Sounds like you have a leak around the door bellow somewhere, or your drain pump. The bellow is the rubber gray boot the seals around the wash tub and door. You will need to remove the bottom panel under the door to be sure. Remove the screws under the bottom edge of the panel. Once removed, the panel will drop down, then off. Inspect the washer with a load running. If the bellow leaks, a tell tale sign will be moisture showing up on the concrete counter weight in the front of the washer. Double check your drain pump and hoses as well. The pump is located directly under the wash tub in the front of the washer. The water tends to pool in the cabinet before it leaks out and drops into the pedestal drawer. If the bellow is leaking, make sure inspect it for rips and tears. You may just have a banding clamp that is loose. If the pump is leaking, make sure the clean out trap is on correctly and snug.
PS If you just purchased this washer and are experiencing problems already, this repair is covered under the one year limited warranty. Inspecting for a leak is not going to void the warranty. However, removing any major parts may. Just do an inspection to see if it is something obvious. If you suspect a part failure, get in touch with the retailer. If this was purchased from S**rs, they usually have a 30 day satisfaction guarantee. If you are not happy with the appliance, they should take it back.
Please let me know if you need further assistance.
SOURCE: How can I remove the Whirlpool Duet washer pedestal drawer?
there should be a clip on the top or bottom if not pull it out as far as it will go grab it on both sides and pull sharpley towards you DO NOT GRAB THE FRONT IT WILL BREAK
how does the drawer come out of the base
