Washer will not spin water out and made loud clunking noise when it was running. It is about 4yrs old - bought from yard sale a yr ago. Worked perfectly untl one month ago when it started with noise and now tonight it will run for 19 minutes then stop. Will not spin water out or anything else. Just show code "ld" . Do not have manuel to look up. Now I'm dumping water out by hand since I was stopping and starting trying to get to work. Most water I've seen in it since I had it. It has never dispersed enough water - doesnt get clothes clean since there is barely any water coming in. Is that normal for this washer - the very little water?
SOURCE: Loud noise when draining and spinning
It sounds like it has something to do with the pump which can be located in the direction of the noise. It could be something as simple as the belt wearing out or even just the pump came loose off of its mounts. Worst case scenario would be a new pump but it honestly sounds like something a little less intrusive. I know I had one that I had to hold down with a bungee cord because the mount had broken off of it.
SOURCE: Kenmore Oasis HE Washer
problem started when washer started itself up twice in the middle of the night....after that the washer seems to have problems figuring out what it wants to do...when running a wash it will start, run for 2 minutes then start scanning numbers...it does not land on a code...it will spin, stop, start...sears has replaced the mother board 3 times....and we will be phoning them again as it has not fixed the problem..one other time it did not spin properly and clothes were wet...we have a dedicated surge protector on it...we have had our electrical checked and no problems there...sears confirmed that as well..the techs have given up on it and don't know what to do with anymore...it is still under warranty and now costing sears more to service it then replace it....time for them to do the right thing and "take it back"...very disappointed in this washer...wish me luck when i call them again...they must be sick of hearing from me....lol
SOURCE: Kenmore Oasis HE 27082 Displays "LD" error falsely
remove the harness and replace it is what this will lead to,just watch and you'll see
SOURCE: Loud grinding motor protesting humming w/no spinning or agitating
The drum/agitator bearings are bad I believe, or the gearbox has been damaged. This is an expensive repair. I would strongly consider buying a new washer. This is a great time to buy appliances since the stores are really competing, and the prices are at their lowest.
Ray
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
