Admiral Side by Side Fridge is warm at top, cold at bottom
Top of freezer and top of fridge are warm. bottom of freezer and bottom of fridge are cold. vegetables are freezing in drawers and on shelves near bottom on fridge side.
do i need to take off a cover to replace? i see vents in back of freezer, and no air coming out, no noise of a fan running.do i need to take off a cover to replace? i see vents in back of freezer, and no air coming out, no noise of a fan running.
my freezer is not freezing at top but is okay at bottom. There is a fan inside at the top and it is not working. It looks like that is the problem as there is no way the air can circulate, also the door is normally difficult to open soon after closing it but now its easy to open.my freezer is not freezing at top but is okay at bottom. There is a fan inside at the top and it is not working. It looks like that is the problem as there is no way the air can circulate, also the door is normally difficult to open soon after closing it but now its easy to open.
Got exactly the same problem. Had a look at the back of the unit but can't see a fan. There is definately nothing blocking anything...Got exactly the same problem. Had a look at the back of the unit but can't see a fan. There is definately nothing blocking anything...
Yes this is the problem I have and I am sure that the fan is the problem. can a part be purchase and fitted by any one handy?Yes this is the problem I have and I am sure that the fan is the problem. can a part be purchase and fitted by any one handy?
AnonymousMar 13, 2014
bosch side by side fridge freezer not freezing at topbosch side by side fridge freezer not freezing at top
AnonymousMar 16, 2014
SIDE BY SIDE DAEWOO FRIDGE FREEZER MODEL FRS-U201CW TOP OF FREEZER NOT FREEZINGSIDE BY SIDE DAEWOO FRIDGE FREEZER MODEL FRS-U201CW TOP OF FREEZER NOT FREEZING
AnonymousMar 18, 2014
It is hotter on the top of fridge than the sides. Warm area is on both sides where the fridge part and freezer part meetIt is hotter on the top of fridge than the sides. Warm area is on both sides where the fridge part and freezer part meet
AnonymousMar 22, 2014
snow in bottom freezer drawersnow in bottom freezer drawer
AnonymousMar 27, 2014
freezer cold and fridge warmfreezer cold and fridge warm
AnonymousMar 31, 2014
The bottom of the freezer is cold not freezing. The refrigerator is chilled at the bottom top is warmThe bottom of the freezer is cold not freezing. The refrigerator is chilled at the bottom top is warm
You can't post conmments that contain an email address.
check yor damper door, it's the little door at the top and or bottom of the fridge insid near the top and or at the bottom behind the crisper drawer when working right they open to let cold air in from the freezer and warm air out. top one cold in, bottom one warm air out.they work on a sensor/relay when the freezer fan goes on they open when cold air is needed.
3 things If you have ice on the freezer side. 1. defrost timer not working 2. blower fan failed, if it has one 3. defrost limit switch failed.. i dont think it is #2 but 1 or 3 last but not least your defrost heat coil has failed
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
THE CONTROL THAT DIVERTS MORE AIR TO FREEZER AND LESS TO RE-FRIG SIDE COULD NEED TO BE ADJUSTED TO KEEP MORE AIR IN THE FREEZER SIDE , MAKE SURE ALSO THAT THE SMALL FAN IN THE FREEZER IS RUNNING , ALSO TURN THE THERMOSTAT CONTROL TO LESS COLD , IF YOU HAVE A THERMOMETER TO PLACE IN FRIG SIDE TRY TO KEEP @ APP 40 DEGREES IN FRIDGE SIDE SEE IF ANY OF THESE HELP
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
Found a fix for my issue ... hopefully it'll help you. Up at the topleft rearmost corner of the fridge remove panel to reveal spring attached slots where cold is supplied from freezer. The spring attached had came off one end as there isn't a "slot" for the spring to hold in place (design fault?).Reattached the spring and taped on .... and hey presto fridge now working perfectly again. Hope this helps.
All the cold air from your freezer gets pushed into the fridge with a fan in your freezer section. So your problem is from the fact that this cold air isn't get to your fridge.
- the door that allows this cold air into the fridge, normally in the top left corner of the fridge, is stuck shut and needs replacement.
-the freezer isn't defrosting and restricting the air flow
-the temp controller for the fridge is damaged and thinks that the fridge is cold enough.
I have the same problem, please help
Cooling fan is not running... where can I get a fan motor.
