Tip & How-To about Televison & Video
Do you want to still be able to use that trusty ol' VCR to be able to record your TV shows but can't seem to do so now that you have gotten a Cable Box?
Well here are some simple tips on how to connect all the components and not compromise the quality of the incoming signal of the cable signal feed.
First here are the cables you will need.
3 sections of Coax cable (preferably RG-6 quality)
or
2 sections of Coax cable (preferably RG-6 quality)
1 RCA cable (Yellow/Red/White)
Now here is how you will need to hook up the cables properly.
1) Connect one Coax cable to the incoming cable signal feed. Usually a screw on connector on the wall or line coming up through the floor.
Now connect the other end of this cable to the "Cable in" or "Input" located on the Cable box.
2) Now, connect one end of another Coax Cable to the "TO TV" or "OUTPUT" on the back of the Cable Box. Now connect the other end of this cable to the "CABLE/ANT IN" or "INPUT" connection on the back of the VCR.
3) Now, connect the last coax line from the "TO TV" or "OUTPUT" on the back of the VCR. Now connect the other end of this cable to the "Cable IN" on the back of the TV.
***** ALTERNATIVE OPTION FOR THIS FINAL CONNECTION******
Using the RCA cable connect to the "VIDEO OUT" RCA connections on the back of the VCR and connect the other end of this cable to the "VIDEO IN" on the back of the TV.
Now this is how you will need to set your VCR and Cable box to make your recording.
1) Tune your VCR to Channel 3 or set your timer to record Channel 3. (The actual channel you are going to be recording is controlled by the Cable Box)
2) Tune your cable box to the channel you wish to record.
*** Note: Some cable boxes have an auto tune feature that will tune your cable box to a channel while you gone. Contact your cable provider to see if this is available on the model that you have***
