HI, I have got a problem with my kawasaki ZR7 (2000) gearbox, when I started my bike this morning (tem is -1C) When I engaged to 1st gear the lever didn't spring back to it's position (it stayed on the bottom) so i had to pull it back myself. it seamed I have got the same problem with all 5 gears (lever doesn't spring back)
When I left bike for 7 hours outside garage I couldn't shift to any gear at all. So what do you thik? is there a problem with cold weather or I simply bent my shifting forks? Thank You, Ted
SOURCE: kawasaki vn1500 classic 1st gear problem!..
it sounds like you have a broken dog on 1st gear. (on sprocket inside gear box) gearbox needs stripping down and investigating.
SOURCE: 2006 kawasaki kx85, only shifts to first gear and
Your dogs are grounded out. You are going to need your trans overhauled.
SOURCE: Hi, my 1994 KX 250 will not engage 4th gear
The worn shift fork is the problem. Normally a shift fork will never show any wear. When a fork gets bent is when wear begins to show. If a good shift fork is set side by side with a bent fork it is very hard to see any difference. The bend is so slight that it is usually impossible to discern. Put in a new fork and the shifting problem is history.
Now would be a good time to install new crank bearings and new crank seals as well.
