Bought two new batteries for my 18v cordless drill makita mxt 8444D. Batteries are 2.6 Ah 1834 NI-MH. The charger is Ref DC1804F. When inserting batteries into the charger the green and red light flashes alternately. This would suggest that the batteries are faulty - however, they are brand new.
Salve!Ho lo stesso problema.Con batteria a 13 volt il caricabatteria mi indica rosso e verde lampeggiante.Con il tester vedo per? che sui poli + e - del caricabatteria ho 0 volt.Inoltre i 2 fusibili interni sono ok.Cos'? successo?Aggiungo il fatto che il caricabatterie ? adatto per ni-cd e ni-mh
That is the correct charger for either nicd or nimh batteries. It should work. Even though your batteries are new, they could be old stock, and they degrade sitting on the shelf. Return the batteries.
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
I just submitted a post for the same problem with my two Makita BL1815 18v batteries...red and green lights flash and won't charge...
its the charger that came with the drill and used to work fine
battery fully charged but still not working
Red and orange light on my makita charger
makita battery 18v dead
Manual only mentions temperature to charge. Not sure what it means
when i plug the charger in and place the battery on charge it wont charge and only the power light flashes green
I require a new battery for agojama drill.can yoou suggest supplier or alternative
