Toro Lawn Mower With Toro Power Tools Logo
Anonymous Posted on Jan 08, 2010
I have a toro ccr 2450 snowblower. i bought it
I have a toro ccr 2450 snowblower. i bought it last year and used it once. this year i used it for the second time and the belt shredded - auger stopped spinning. i replaced the belt, got half my driveway done and the new belt shredded. what gives? if my gas/oil mix is too lean, could the engine heat up too much, overheat the spindle that turns the belt and actually melt/damage the belt? or is something else going on?
Rocky Ridge Mowers
Level 2:
New Friend:
  • Expert 71 Answers
  • Posted on Jan 08, 2010
Rocky Ridge Mowers
Expert
Level 2:
New Friend:
Answers
71
Questions
0
Helped
40651
Points
301
No if your belt is shredding there is something rubbing on the belt. Check the idler/tightner pulley see if it spins freely. Check make sure nothing but the pulleys are touching the belt when it is engaged.
Sam
Testimonial: "Thank you for the quick response."
2answers
Toro CCR 2450 Snowblower has new plug & gas but will only start with added starter fluid then will run until trying to start again.
Question edited for clarity.
When you put it away at the end of last snow season, I expect you just rolled it to the corner of the garage and left it until now? The two stroke gas in the carburetor, went bad and gummy. It starts on starter fluid because no gas is coming from the carb.
https://www.google.com/search?q=toro+ccr+2450+carburetor+cleaning
Jan 19, 2024 • Toro Garden
Toro CCR 2450 snowblower won't start.
Try a short burst of starter fluid into the carburetor and promptly pull starter. If it runs for a couple seconds and quits then the carburetor is not delivering fuel.
If it doesnt run on starter fluid then either flooded, insufficient spark, or poor compression / crankcase leak.
Oct 26, 2019 • Toro Garden
1helpful
1helpful
Other problems know with the toro 1000c 3hp snow blower model 38195
My blower runs fine and has no problem all I do is keep it nice and clean after use and oil the running parts after the season when I dont use it I am very happy with it.
2answers
Toro CCR 2450, Common starting problems? Fresh gas/oil mix. Good compression. Just pulls, no pops or sputters.
Next step would be to check the ignition module(coil),I have a lawnmower that uses the same 2 cycle engine. Check coil for spark by removing the spark plug from the block then connect the insulator side of the sparkplug back to the coil then ground the plug by touching the threaded side to the block away from the sparkplug hole while turning the engine over. Should see a spark, if not you'll need a new coil,not hard to replace. calls for Briggs & Stratton #80-1268 you can also use a Toro/Lawnboy coil #99-2911 or #99-2916 or #684049.
8helpful
What is the gas/oil mix for a Toro CCR 2450?
Hi my names Dane, and I'm going to help you.
The mix on the toro CCR 2450 is 50:1 I don't know if you;re having any more problems, but I wanted to include this link for you to check out. I'll let you judge.. Thanks! Dane
http://mattfleming.com/node/45
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
