Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
Anonymous Posted on Jan 07, 2010
Mitsubishi wd-62725. 8 power supply caps replaced
Mitsubishi wd-62725. 8 power supply caps replaced but no power at all from power supply curcuit board, still. What else on the power supply board can cause a no power condition. Any solutions?
  • Anonymous Jan 08, 2010
    where is fbt located and what doews fbt stand for is it the main transformer on the power supply curcuit board?
  • Anonymous Feb 25, 2010
    Correct no FBT, Wireing good. All fuses on power supply good, completely dead no response
Chi Chu
Level 3:
  • Mitsubishi Master 8,457 Answers
  • Posted on Jan 07, 2010
Chi Chu
Mitsubishi Master
Level 3:
Answers
8457
Questions
0
Helped
2820752
Points
26282
Replaced the FBT,that help the power too.
  • Chi Chu Jan 09, 2010
    It call the Flyback Transformer.It a big block of plastic with a red wire solder to a deflection board.Try website Tv repair World.com.For parts informations.
Anonymous
Level 2:
Scholar:
  • Expert 62 Answers
  • Posted on Feb 06, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
62
Questions
26
Helped
32475
Points
109
I'm pretty sure these dlp's don't have the flyback transformers mentioned. If you have no power make sure all of the wires are connected again. Does the unit appear 'dead' or is there any indication of response?
    You don't even get the green blinking timer light when you plug it in? I assume not, because you said the unit acts dead. I tore one of these apart last month on 4 different occasions, but we always had some sort of response. I'll look around the web and see if I can find anything helpful.
Tv wont power up after replacing 6 caps 4 bad 2 looked good but were in series so replaced with larger voltage. mitsubishi wd 62725
That model will usually have 8 caps that require replacement on the Power board and also 4 capacitors on the DM board which will usually cause the Non stop blinking light symptom.
I need to replace the power supply for my Mitchubishi WD-62725
Required power supply board for Mitsubishi WD-62725 is available in discount-merchant.com for $110
Let me know if you have additional question.
Thanks.
Replaced caps on tv worked then I turned off and now green light is flashing non-stop again. What's wrong now ? Please help
You'll have to check your standby voltages and make sure they are present. If they are not then the power supply needs repaired or replaced. Caps, as they are going bad can fatigue a power supply.
Mitsubishi Capacitor Problem
hello where are you located if your in england try a place called wiltsgrove in birmingham 01217722733 or try ebay good luck
regards
shaun
Tv won't turn on?
Your main boards are bad. The FMT, DM, & Power Supply. They are no longer available, You have to have the chasis rebuilt. Mitsubishi is rebuilding these chasis. You have to pull it without any cut wires & ship to Georgia.
tvdoctor
3helpful
Blinking green timer light
I purchased my WD 62725 in January of 2005 and have had way too many problems with something costing this much.  My green reset button is now blinking and I have read and tried all of the suggested solutions. All of them have failed.  I sure think Mitsubishi should be held more responsible than they seem to be.  Some one suggested a class action lawsuit.  I would sure join one.  Jack P
2answers
2helpful
3answers
Timer light blinking
Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
