Posted on Jan 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Konica minolta Bizhub C6500 error code 2424
  • Anonymous Mar 30, 2014
    Error code C2812
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 15, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2228
Points
Hi, I have a C6500 Bizhub pro, but, recently displays an C2404 error. I need to print an urgent job and y can't!
Please helpme!
Copier Jocky
Level 2:
New Friend:
  • Expert 53 Answers
  • Posted on Jan 10, 2010
Copier Jocky
Expert
Level 2:
New Friend:
Answers
53
Questions
0
Helped
29129
Points
106
Http://onyxweb.mykonicaminolta.com/ocp~eng/sso.asp
try knowledgebase
Konica Minolta bizhub PRO C6500. Hello, can anyone help me? Do I have a problem with code C2221?
Question edited for a lot more clarity.
Question translated to English, we only speak English here.
Question moved from Televisions category.
Konica Minolta Bizhub PRO C5500 Solution Manual (Page ...
ManualsLib https://www.manualslib.com > ... > Solution manual
Reconnect the terminal. 2.Failed ...
Accurio c2060 error c2221
Copytechnet https://www.copytechnet.com > ... > Konica Minolta
Jun 26, 2023 - C2221 can be caused by toner dusted sensors PS50 & PS51. I've seen C2221, when the drum bore fits too tightly onto the drum shaft. The imaging ...
Error Code C-2221 on C7000
Apr 3, 2019
C6500 Error codes C-2211 - C-2214
Aug 7, 2008
bizhub PRESS C1060 multiple codes/symptoms
Jun 21, 2022
C6500 C-2220 error
Jan 22, 2014
More results from www.copytechnet.com
Error code C-2704 mean on C6500 Bizhub Pro
Abnormality in the black charging unit.
Possible causes:
Black charging unit
HV Unit
Print Control Board
My best guess is that you have a faulty charge unit. Try swapping the units around with another colour and see if the fault code shifts.
Error code 3501
HI
I HAVE KONICA C6500
ERROR CODE 3501 and 3802 but know the error 3501
I know it rech high temperature I change the sensor 1 UP fuser roller
and I reset the error, the machine start and stop again with error 3501
1helpful
Error code 4701 for Konica Minolta bizhub pro C6500
- 4701 error
Communication fifo problem error 4702/4701 of 5500;6500;6501 konica minolta mfp printers
1) reseat all connectors in Ipb
2)image memery controle board
Inspite doing all these if the problem persists please reload the firm ware/flash firm ware.
Last one is to replace image memory board only .no need to replace prcb; overall status board; nvram
2helpful
2answers
11helpful
4answers
What does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
