Kitchen Appliances - Others Logo
Posted on Jan 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wireless door bell rings when no one there
A neighbours wireless door bell chime turns on the chimes at my door bell
tfelton3
Level 2:
New Friend:
  • Expert 183 Answers
  • Posted on Jan 07, 2010
tfelton3
Expert
Level 2:
New Friend:
Answers
183
Questions
Helped
63940
Points
490
Most likely on the same frequency! They have a pretty good range on them, I'd go but a different brand!
TR-6505-RX by DESA SPECIALTY PRODUCTS. The door bell is not working. We put in new batteries in the button and also the chime box. How do we get the door bell to work?
Did you read the manual?
You need to pair the bell push and the chime unit with the same DIP switch settings. They do this in case you and your neighbours have the same unit. Someone press the doorbell and you all come to your doors. :>D
WIRELESS MECHANICAL BATTERY OPERATED CHIME
Trine Access Technology http://www.trineonline.com > 235_instructions PDF This device (WB-94A-TX or WB-97-TX/TR-6505-RX) complies with Part 15 of the FCC Rules and RSS-210 of Industry Canada. Operation is subject to the following ...
1 page
Rind doorbell doesn't stop ringing
it is possible that the doorbell button is sticking down and keeping contact - so the doorbell keeps chiming.
WIRELESS DOOR BELL BUTTON SL-1695-rx
Heath/Zenith SL-6166-C Wireless Plug-In Door Chime Kit ...
www.amazon.com > ... > Door Chimes & Bells > Kits
Amazon.com, Inc.Heath Zenith SL-6198-B Wireless Doorbell Replacement Battery. Total price: ... Plug-in doorbell chime, doorbell button/transmitter with battery, hardware pack ...
My bell ring everytime my next door neighbor's bell ring & even the neighbor three doors down. What is up with that?
They're all set to seeing frequency you need to go into your owners manual and check how to change wireless frequency
1helpful
Will my wireless bell push work with another manufacturers door chimes?
Doubtful they are compatible. If they are set by dip switches and you set them the same bot doesn't work-not compatible.
1helpful
3answers
Phantom bell rings on Siemens wirreless door bell chime jsjs-204, I do not have instructions
You may need to change the frequency of the chime. In this model, you need to remove the batteries from the receiver unit and wait for a while. Then replace the batteries. The doorbell unit should automatically set itself to a different frequency once you press the button, which will(hopefully) solve the problem.
It seems impossible to find the instruction manual for the doorbell. But see http://oddsnsods.net/blog/?p=68 who had a similar problem with a different Siemens model, which works on the same principles. (I can't seem to be able to remove the battery from the door bell unit on the jsjs204, but it reset itself after changing the batteries in the receiver).
1helpful
I have a desa DD100S wireless door chime but for some unknown reason the bell push is not working, I have tried replacing the battery but still unable to ring chime. The actual base unit is fine and...
Sandra, the contacts in bell push may need cleaning, as well as some minor readjustment of the contacts. Insects love to get into the bell push and can clogged it up. If you find that this doesn't solve the problem, Contact the Zenith Company 800-858-8501 to purchase a replacement.
4helpful
'Doorman' chimes keep chiming, without bell being pushed
I had the same problem - turned out to be a cordless phone nearby. If you have one, try moving the bell away from the phone or vice-versa. Another possibility is a neighbour with the same code. There are some jumpers you can move around to change this.
8helpful
My doorbell also ring neighbor's bell
Change pin configuration on plugin bell and the remote.
The pin configuration should match
Top Kitchen Appliances - Others Experts
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
