This could be a hard drive crash, however, I just repaired a machine that had a similar issue. A loose connection an the board was prompting the machine to blue screen, and then shutdown all together. I had to tear the machine completely down to find it.
Did it at anytime lose power during updating? If so, motherboard was damaged and needs replaced. Otherwise, try to boot into'Safe Mode with Networking' and if it turns on, immediately re-install your graphics (video) driver. See this link for instructions on booting in to safe mode on a Toshiba: http://forums.toshiba.com/t5/Windows-7-Knowledge-Base/How-To-Start-your-Windows-7-computer-in-Safe-Mode/ta-p/272525
what indication do you have on the monitor if any? does the monitor power on for a few minutes or does it always stay black? try unplugging all USB devices and restarting the machine.
Following is the link to download all drivers for Toshiba Equium A210 running Windows 7 32 bit,Please download each driver and install them one by one.After that keyboard should work fine:
Try starting in safe mode. Hold down oth the control and F8 kays and press power. Do not release Contro & F8 until it starts to beep. Then it shoud start in safe mode. If the computer will not start in safe mode you have a hardware problem. If it starts in safe mode, you have a Windows problem that re-installing Windows will solve that (to a point). Without the Original CD and install code, you have two options. Buy a new OS or.......pirate it. I do not recommend the last.
it may be driver problem. look for an updated driver by 1. going to windows update website and do a manual update and look for a new driver for your camera or even better, 2. check toshiba's website's knowledge base for solution if there's a specific fix from toshiba or a possible update for your driver. (i was trying to do that for you but the website is currently down 11-7-08 at 12:33am) http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Product%20Support give a try hopefully you will have better look due to timing.
check also device manager and find the status of the device and post back with your findings on that device.
lastly.. you way have to give him a call, some problems are hardware related and if your product is still withing warranty you may need to send them your laptop for them to have the issue corrected or the laptop replaced.
