F2 E1 is an error code that says the membrane (touch pad assembly) is not connecting to the ERC(Electronic Range Control). Call the warrantee company and give them the model number and serial number of your range and ask them if it still has a parts warrantee on the electronics. If it does, they will have to send their technician out to replace the part or parts and charge you for the labor. Your model may have the membrane and Erc all in one part, so an easy diagnosis, if it is seperate you need to make sure the membrane ribbon connector is plugged tightly into the Erc, plug your range back in, press cancel, and then retest. If it still fails then replace the membrane, test and if it fails again, replace the Erc. Before you tear into this make sure you unplug the unit for 30 minutes, plug it back in and test. Sometimes this will reset the Erc and solve your problem. If it doesn't the make sure you unplug the range before doing any repair work. Good Luck, Appliance Specialists
Good Morning, An E1-f2 E1F2 error indicates a faulty touchpad. Fixyourboard.com offers replacement Ledgestone Technologies touchpads for Kitchenaid oven models. Reach out to them for more information 512-355-1108 or [email protected]
I think, that the temperature sensor it's defective, try replacing it, it's the cheappest way to solve the problem, if this does not work then, you will be spending more money on the timer electronic control.
Hi
F2-E1 Error indicates
a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is
bad and should be replaced. To solve this issue test the oven temp. sensor, it
should read between 1080-1120 ohms, if the rating is more then that and the door
appears to be closing fine then it is the control board that is bad and should
be replaced. Hope this helps...please post back for further assistance.
Daniel
