Canon imageRUNNER 400S Copier Logo
Posted on Jan 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our Canon Image Runner 330S shows error message E014....
Machine will not start after turning off and on as per message. Is there a code to clear the error?
Anonymous
Level 2:
New Friend:
  • Expert 170 Answers
  • Posted on Jan 05, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
170
Questions
0
Helped
47521
Points
280
Is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 30, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1111
Points
My cannon IR 330s has an error code E014 give me a solution to this please
Tapa gopa
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Aug 06, 2013
Tapa gopa
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2194
Points
5
Check the D.C. Board or Fixing motor
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Posted on Jan 21, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
1111
Points
I have cannon ir 330S I am geting error code E014
Cannon Image Runner 400S has an ERROR E014 (Fuser Drive Issue), how to fix it
your fixing motor has faulty rotation.
check main motor M2 , DC Controller PCB and image processor pcb
I get an error message E 014 on my image runner 330S Pleae help me to identify as to what it is
the code indicates the failure of fixing motor. there can be jamming in fixing unit, either one of te gears or the roller bearings may have jammed,or fixing motor failure.
Need steps in removing old toner from canon image runner 330S copier
open front cover, release developer lever at right,release feeder lever at down right corner,unscrew the centre screw at the top of the drum unit, slide out the drum unit, at the back of unit u will find a clear plastic cap remove it and empty the waste toner reverse all the process to place all togather.
3helpful
2answers
1helpful
2answers
Our Canon Image Runner is showing the error message.....E00001-0010 What does that mean? Thanks
You have a problem with our fuser assembly - located where you pull out the left printer door - it is the very hot assembly where the paper leaves the machine - it will either have a yellow or black felt cover. Only two screws hold this unit in - one at the back and one in the font. Take this unit out and look for trapped paper in the rollers that could also cause the fuser temperature readings to be incorrect. If you cannot find any paper, reset the code in service mode and turn the machine off/on. If the problem returns as you power on - you will need a new fuser unit. To clear the fuser error enter service mode as follows:
Press the head key (head shape with star inside) - 2 and 8 at the exact same time - then HEAD key again. You should now be in service mode. Now - COPIER - FUNCTON - CLEAR - ERR - OK. Then turn off the power and on again - this may cure your problem indefinetly or definetly. But even if you find paper in the fuser, you mUST perform the CLEAR procedure or the error code will not go away. Good luck.
2answers
Image runner 4570
it might just be a power spike in which case your machine just shot an error while it protected itself...
try the following...
press additional functions
press 2 and 8 at the same time
press code error
press copier
press function
press clear
press error
press ok
press reset
if that doesn't work then call a tech... it might be very serious...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
2answers
Error code e000007-0000 for a canon image runner 22006
You have a problem with the fixing film. It is not a case that you have to reset the machine and carry on. Replace faulty parts in fixing and then clear the code. Most probably you have a damaged fixing film.
Adding Staples Image Runner 330S
depednding on sorter im guessing its the small sorter with one tray the stapler is in the rear of the sorter green handle pull it out uses L 1 staples
1helpful
2answers
Canon Image runner photocopier
It is very easy... What code is it? It may not be resetable with out replacing a part... Need more info...
old marine
old marine
ZJ Limited
ZJ Limited
