This worked for my QX3 on my Vista computer!
Instruction for installing the QX3 Microscope with Vista
Note, DO NOT use the software from the CD that came with the microscope.
DO NOT plug in the QX3 microscope until Step 4.
Step 1. Install the QX3+ downloaded from Intel:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419&strOSs=All&OSFullName=All%20Operating%20Systems&lang=eng
Step 2. Download and install the QCODINSTL Codecs software from:
http://www.intel.com/support/intelplay/qx3/sb/cs-016002.htm
Step 3. Download and extract the QX3 Drivers from:
http://hyperslug.s3.amazonaws.com/IntelQX3driverXP.zip
Step 4. Now, plug in the microscope.
When the "Found New Hardware" wizard appears, select "Locate and install driver software (Recommended)", a message "Installing device driver software" will appear. If you click on "details", you will see "Searching Windows Update", after a while you will be able to select "I don't have a disc. Show me other options" and browse to the folder with the extracted QX3 drivers from Step 3. above. The hardware should install successfully.
Double-click on the QX3+ icon on the desktop and the program should run.
Email Digital Blue and they will ask for your email address and shipping address. Looks like they're starting to send out the Vista version on cd via the mail, then make it available online for download later. Best of luck!
Thank you
Here are the instruction for installing the QX3 (or QX3+)
Microscope with Vista. You must be using a 32-BIT VERSION. The QX3 is not
compatible with 64-bit versions of Vista.
Before you run the programs below, right click the icon, click on
"Properties", click the "Compatibility" tab, check the box
next to "Run this program in compatibility mode for:", then choose in
the drop-down box "Windows 98 / Windows ME". You should also check
"Run as Administrator" if your account is a "Standard
user".
Step 1. Download and install the QX3PLUS.EXE software from Intel:
http://tinyurl.com/qx3plus
or
amp;strOSs=All&OSFullName=All%20Operating%20Systems?=eng
Step 2. Download and install the QCODINSTL.EXE software from:
http://tinyurl.com/QCODINSTL or
http://downloadcenter.intel.com/Detail_Desc.aspx?strState=LIVE&ProductID=160&DwnldID=2089&agr=N&lang=eng&PrdMap=160
http://tinyurl.com/IntelQX3driverXP or
When the "Found New Hardware" wizard appears you will see a message
saying that the driver installation was not successful. Click the Close box.
You need to install the driver manually by following these steps:
a. Click START - Select Devices & Printers
b. Right-click on the Intel QX3 Icon and select Properties
c. Click the Hardware tab - click Properties
d. Click Update Driver - select "Browse my computer for driver
software"
e. Browse to the folder with the extracted QX3 drivers from Step 3. above. The
driver software should install successfully.
user".
or
software"
user".
or
software"
Currently usiong XP-H/E, and XP-PRO update planned to VISTA. Need driovers for QX3 scope.
need drivers for vista
i have a qx3plus and need a download for vista
Tried Solution #2 on Vista Home 64, last step would not complete
my intel play qx3 microscope wont work for my vista computer!!!
i need the drivers to opporate this same microscope on my windows vista laptop
DIGITAL BLUE'S REPLY IS THAT QX3 AND QX3+ IS NOT COMPATIBLE FOR VISTA
i need the drivers for my microw scop beacas i have lost them
