Kitchenaid mixer makes a lot of noise. The beater hits the bowl with too much force and noise and does not mix the food at bottom of bowl. It seems off center.
Hi - I've been searching for general info on KitchenAid stand mixers and ran across this so I'm throwing my $.02 in... Since KA stand mixer bases are essentially made of cast metal parts, there is a very slim chance that there is a lateral misalignment (side-side) unless it got dropped...eek! Sounds like a head height adjustment issue. Check out this from KitchenAid Conversations:
http://forum.kitchenaid.com/forums/topic.asp?TOPIC_ID=3032
Good luck.
DZII
Testimonial: "Thank you for your post. I will check out the suggestionsl"
Make sure its the right beater yours is a 6qt bowl . If the beater is for a 5qt stand or artisan it won't li e up on the bottem or the sides.
