For a Step-by-Step instructional PDF on how to disassemble, clean and reassemble your Magic Bullet send an email request to: [email protected].
If the coffee spill has not affected the performance of the machine, then I would let the liquid dry before next use and it should be okay. I have spilled liquid down into the base before and it has been fine. It usually leaks out the bottom, but does not interfere with the performance of the machine.
SOURCE: My Magic Bullet has broken. I need to know how to get it fix.
This happened to me, and I was told by the company that I had to purchase a brand new base, that the plastic turning device can not be repaired. If it is under warranty, you may not have to pay anything but shipping, and maybe not that either. If you do not have the number to the company, go on-line and and search for it. Call the company and report what the problem is.
SOURCE: Magic Bullet Blender Repair
i had the same problem,broken plastic drive gear.
solution ; sacrifice one of the blender choppers bases you use the least (usually the flat cutter)
hold the cutter blade with pliers or in a vice if you can and unscrew the rubber gear off the shaft in a clockwise direction -- CLOCKWISE--DIRECTION-- easy huh.
Now insert screwdriver to suit,(coss,phillips or flat blade type) into centre hole in underside base of power head drive unit. Hold unit firmly and now unscrew broken gear or brass centre piece left behind CLOCKWISE again off spindle.
Finally screw rubber gear back onto motor spindle in ANTI clockwise direction. DO NOT over tighten. Rotation of motor and drag caused by blending action tightens assembly with use.
Done. for pics follow this link
http://www.ehow.com/how_5137984_repair-magic-bullet-blender.html
SOURCE: where to buy a magic bullet base gear?
The base gear/ top gear is available on ebay http://www.ebay.com/itm/Top-Gear-Spare-Part-for-Magic-Bullet-MBR-1701-for-on-top-of-the-Power-Base-/310396184641?pt=Small_Kitchen_Appliances_US&hash=item48450de841#ht_559wt_700
