It's a Zanussi, electric double oven an grill ZCE 7702.
The main oven is not giving any heat. The oven (temperature) light on the top comes on, the fan sounds as though it is working but, not as powerful as usual but, no heat!. The top oven and hob still work!
Sounds as if your oven heating element has failed. You need to fit a new one.
Usually you have to get the back off, disconnect the old element, remove the fixxing screws and element, fit new one, reconnect and it should be fixed. Don't forget to switch the power off before starting work.
hi not sure if you've had a reply but when my zanussi main oven stopped working i just changed the element (purchased from e bay).
open oven door and the back you will see 4 screws(basically 4 corners) remove these screws and you will see the element, pretty straight forward to remove, obviously fan wont work until you have heat (hopefully fan ok) you can give this a go, cheaper than buying a new oven. i have done this twice. hope this helps.
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Hellostarsevern!!Did you get your cooker fixed, what was the problem? I have a Zanussi ZCE7550, but apart from that I'm in exactly the same predicament as you in the post you made on Sep 18, 2010... Can anyone help with a suggestion please???
It sounds like a faulty thermostat, because when you turn the thermostat on it should supply the oven element and the neon light, so even if the element is faulty, the neon light should still come on regardless of the element working or not.
Hope this helps.
You need to replace a faulty main oven element.
This is done by removing the rear cover in the main oven,
there you will see the element, disconnect and replace.
It is not a difficult job , and is not too expensive.
Plz frate my solution.
THANKS.
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
almost certainly a problem with the fan and motor. try moving fan blade with a small screwdrriver thro the holes in the back panel to see if it is jammed. after that you are faced with removing appliance, remove back panel and check motor continuity
