The first thing i would check is your boot around the door for a rip or tear. Also check the drain line for any types of leaks. You can also remove the bottom panel there will be three torx screws and you can look at your drain pump while in spin and drain cycle to see of the leak located in that area.
you may not be leaking out the bottom. Your stand pipe may be clogged. If the stand pipe has a slight clog in it, the stand pipe will over flow, and the water "looks" as if its leaking from the bottom... These pump faster than your old machine, so the pipe will back up faster... hope that helps
looks like your washer is developing a leak from the seals in the drum thus allowing some water to seep into the bearings get it checked before the bearings run out completely
hazy, it's possible it's running out your pump. You need to pull the cabinet off to get a real look at where the leak is coming from. Check out the pics...and post back.
