Hi There
I found this for to read so you can fix your door.I hope this will help you.Let me know how it goes.
The oven door won't close
If
your oven door has gotten bent or warped (maybe you rested something
heavy on it…), you need to remove the door, disassemble it, and
straighten it. You can lift most oven doors off of their hinges by
opening the door several inches to its first "stop," and lifting the
entire door straight up.
If
the hinges have become worn, damaged, or bent, you probably need to
replace them. We recommend replacing both hinges at the same time, to
prevent uneven wear of the undamaged hinge.
Thank you for writing to fix ya.
Best Regards Richard
You also need to check the bottom surface of the oven: on most models, you'll notice it can slide toward the door from its seated position and prevent the door from closing completely. You may have slid it while cleaning. Just lift slightly and slide it back, then the door will shut.
-DS
SOURCE: Bosch HBL745A Oven door
My husband just figured this out.
- Follow Door removal instruction from the manual.
- There is a screw at the end of the hinge that can be adjusted.
- Adjust the screw to desired height.
- Secure lock nut.
