JVC HD-56G886 56" Rear Projection HDTV Logo
Posted on Jan 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
JVC 56 When you change channels or turn the TV off - you can see blue vertical lines and an area of blue splattered on the screen, and you can see where a channel identification was burned in on the lower part of the screen. Any ideas? Thanks
Anonymous
Level 3:
Genius:
  • Master 1,030 Answers
  • Posted on Jan 29, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1030
Questions
Helped
227520
Points
2244
Thrse television are ila? which i a projection lamp type tv. burn in is internal to optics and will rigure replacment of light engine
JVC HD-56G786 Green Vertical Lines
am thank if you see it in your menu..and on ever channel..you have a bad dmd bord or dmd chip
We have a 56 inch JVC HD-56G786 backlit projector TV and the screen just completely pixelated while watching cable. I turned it off and back on and now even it has a green screen with staticy vertical...
Some of these had problems where the micro for the Dlp gets confused, they have a jig to connect the set to a computer and download two updates on sd cards---it may or may not cure this but this is a shop repair.
2helpful
2answers
I will turn on my 1995 jvc and all i see is a white horizontal line about half inch that won't go away unless i hit the tv then i get my picture back.
The vertical output integrated circuit needs to be resoldered to the circuit board. It's common for these connections to develop cracks over time. When you smack the set it's causing the connections to make contact again for a while. There may also be capacitors in the vertical circuit which need to be replaced as well. They age and change in value.
Blue lines
Hi, convergence amps have failed, your going to need a tech for that repair, involves un--soldering and re-installing parts as well as an alignment, hope this helps, video-tek
Jvc projection tv
try this site http://www.sharefx.net/index.php
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
13helpful
3answers
Got a blue vertical line on me plasma
I had the same problem, a vertical blue line from top to bottom on my samsung TV.
Try this download this http://www.jscreenfix.com/video.php i burned it to a dvd and it fixed it within a minute.
2answers
JVC 36 inch televivision i bouhgt it about 6 years ago
The lightning probably zapped the tuner in you set. If no signal is present the screen is muted (BLUE).This is a feature to prevent your seeing snow on the screen. Stargazer
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
