Check Engine Light and Hesitation or Stumbling While Driving on Mazda Tribute ...this is my second egr valve and car is not picking up the right sped and when ... Mazda Tribute 2003, replacing burnt DPFE, connector bunrt, Need color pinout. ... Drivetrain · Electrical & Lights · Engine · Exhaust & Emissions · Heating & AC ...
A Check Engine Light is turned on when the Mazda Tribute engine control module detects a fault in the emissions system. One or more diagnostic codes will be
You could have a bad coil in the back cylinders. Oil in the plug holes will short out a COP (coil on plug) in these engines, is is a known issue in these (Ford) engines. Do the same routine for the back cylinders, and you should also plan on replacing your valve gaskets/plug seals.
if when running it runs well apart from idle problem i would suggest you have the throttle body and idle speed control valve cleaned out and add a fuel system cleaner to fuel tank also check wireing to idle speed control valve
put the key in the ignition DON'T turn the key, now remote start the car, if it starts, you need a bypass modual, send me a message if you need one and I will let you now where to get the best price where you live
put your key in the ignition leave it in the off position, now press the remote starter, if it starts you need to adjust the key in the 791, or adjust the transponder loop around the key chamber
My wifes car had this same problem at about 100000 miles and after many trips to the shop it turned out to be carbor build up in the intake manifold. A fuel injector cleaner was hooked up and it helped the problem, but did not completely solve it. In oreder to get it totally clean the intake had to be removed and clean it out manually.
