Clarity D613 Cordless Telephone
SPEED DIAL INSTRUCTIONS
To set, replace, or delete one of the nine Speed Dial numbers:
1. If you want to set or replace one of the Speed Dial numbers, and the new number is not already an entry in the phonebook, add the new phonebook entry before continuing here.
2. Press the PHONEBOOK button. The first entry in the phonebook displays.
3. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
4. Press the UP/DOWN buttons (right side of the handset) to scroll to SPEED DIAL.
5. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
6. The SPEED DIAL menu is displayed. If you do not want to make any (more) Speed Dial changes, press the BACK button until the HANDSET number displays, and stop following these instructions.
7. Press the UP/DOWN buttons to scroll to the KEY number that you want to set, replace, or delete; for example, KEY 4.
8. Press the MENU button. A phonebook entry appears. It is either the entry, if any, that is currently associated with the selected key or it is the first entry in the phonebook.
9. Press the UP/DOWN buttons to try to scroll to a different entry in the phonebook.
10. If you are able to scroll through the phonebook, the selected key is not currently associated with any phonebook entry and you have two options:
a. To leave the selected key without an association, press the BACK button and return to step 6.
b. To associate the selected key with a phonebook entry, go to step 16.
11. The displayed phonebook entry is currently associated with the selected key. If you want to leave it that way, press the BACK button and return to step 6.
12. Press the MENU button. A menu displays with two items (ADD and DELETE). By default, the ADD item is initially selected.
13. If you want to associate a different phonebook entry with the selected key, press the MENU button (to choose ADD). The first entry in the phonebook displays. Go to step 16.
14. Press the UP/DOWN buttons to scroll to DELETE.
15. Press the MENU button. DELETED displays. The selected key is now not associated with any phonebook entry. Return to step 6.
16. Press the UP/DOWN buttons to scroll to the phonebook entry that you want to associate with the selected key.
17. Press the MENU button. SAVED displays. The selected key is now associated with the selected phonebook entry. Return to step 6.
To call one of the nine Speed Dial numbers:
1. Press and hold the desired Speed Dial key (1 through 9 on the dial pad). The selected key number displays. If the key is associated with a phonebook entry, the call begins within a few seconds. Otherwise the phone beeps twice.
2. Release the key. If the key was not associated with a phonebook entry, you can either press the BACK key to return the phone to standby, or you can press the CLEAR key and then press a different Speed Dial key..
To review the phonebook entries that are associated with the Speed Dial keys:
1. Press the PHONEBOOK button. The first entry in the phonebook displays.
2. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
3. Press the UP/DOWN buttons to scroll to SPEED DIAL.
4. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
5. Press the UP/DOWN buttons to scroll to the KEY number that you want to review; for example, KEY 4.
6. Press the MENU button. The associated phonebook entry appears.
7. Press the BACK button.
8. If you want to review more Speed Dial associations, return to step 5.
9. Press the BACK button until the HANDSET number displays.
Never heard from anyone. Still have the problem.
