I can't install the software for my new Sharper Image Digital Camera Binoculars. When I open the file "setup.exe" as indicated in the instructions, all I see is a long textedit file, not an installation program. Any suggestions?
SOURCE: What kind of USB cable comes with Sharper Image 10x25 binoculars
Go onto the www.Sharperimage.com web site if you look it will tell you that Sharperimage are in receivership but they do point you in the direction of a support comapny called N.E.W.
In reality you should be able to buy those leads from any decent camera shop or a place like Tandy
SOURCE: Sharper Image Digital 10 x 25 Camera Binocular NEED DEVICE DRIVER
Try This website:
http://www.mscustomercare.com/
SOURCE: I have a Sharper Image
No solution....same problem. Although I have found that if you plug the unit into the PC and launch the accompanying software it will work, but only when plugged in. Once you remove the cable it will go back to the "Hr" state.
Good Luck
What program do I need to down load for my computer to except this camera so I can view my Pictures
How are you opening the file? It should run if you double click on it.
