Yamaha Rx-v365 A/V Home Theater Receiver Logo
Posted on Dec 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Yamaha rx-v365 plugged in the hdmi from cable box
Yamaha rx-v365 , I plugged in the hdmi from cable box to tv and then the fiber optic to receiver from tv (JVC LT40X776 but no sound , fiber optic plugged into the fiber optic for #2 dtv ,
Marek Podmaka
Level 2:
Scholar:
  • Expert 127 Answers
  • Posted on Mar 02, 2010
Marek Podmaka
Expert
Level 2:
Scholar:
Answers
127
Questions
0
Helped
89818
Points
217
You have to configure your DTV input to use optical audio instead of analog dtv audio (red/white plugs). Input assignment should be described in the manual. Come back to me if you have still problems with it.
No sound from rear speakers with TV and DVD player
You also have to connect a SPDIF coax or optical from both the DVD player and from the STBox into the digital inputs on the rear of the receiver. And select them with the remote control.
4helpful
How to connect the PS3 to RX-V365 to get best sound qualitity in films. I have sony BRAVIO LCD wiht PS3 and I recently bought RX-V365 Yamaha home theater system. Please advice on connecting all three to...
You can connect PS3 video via HDMI to receiver and from receiver via HDMI to TV. But RX-V365 doesn't support HDMI audio, so you have to connect audio separately via SPDIF digital cable. I think PS3 uses optical SPDIF, so you will need optical cable. If you can't find cheaps optical cables in your shop, you can try byuing from ebay ($1-5 max.)
2helpful
Sound from tuner but no other devices
The RX-V365 cannot process audio from the HDMI cables (you will still be able to hear it on your TV), you will need to run a seperate coaxial or optical cable into the audio input for the relevant component on the back of the RX-V365.
3helpful
I have my PS3 plugged into my RX-V365 via HDMI then i have my RX-V365 plugged into my Sony Bravia, the problem is i get no Audio through the HDMI input on my Amp but it still comes through the TV how can i...
Run optical or digital coaxial from your PS3 to the receiver and HDMI from the PS3 directly to the TV. Your receiver's version of HDMI will not work, it's 1.1 and cannot be updated. That's the fix, if you want more info on HDMI problems google HDMI issues or problems and you will find thousands of posts and forums on this issue. Short answer though is, you either need a receiver with version 1.3b HDMI or run optical or digital coaxial for audio to your receiver. Hope this helps
5helpful
I have HDMI cable from TV to RX-V365. HDMI from DVD player to RX-V365. HDMI from DirectTV receiver to RX-V365. Speakers attached. I can watch the TV and the DVD player... but the sound is still coming...
the RX-V365 cannot process the audio from the HDMI input. You will also need to connect a seperate audio input (either coaxial or optical) into the relevant input in the rear of the RX-V365
2answers
I just bought a yamaha rx-v365 receiver and hooked to my cable box via a hdmi and optic audio cable. this is working fine but i cant get a dvd player to work via a component and coax audio cable. neither...
Make sure that the DVD player is connected into the correct inputs on the receiver and that the receiver also has the correct input selected to play. If your TV also has component video inputs it is best to connect the player directly to the TV. Otherwise, make sure you have the TV connected to the receiver via component video out.
When connecting hdmi out from my panasonic blue-ray player to the dvd input in my yamaha rx-v365 there is not audio or video,why?
There are several video and audio inputs named DVD. For video you have HDMI, component and composite. For audio you have standard analog stereo and digital coaxial spdif input.
You need to configure the receiver to use the correct inputs - that means HDMI and coax. Also you need to connect the BD player via coax spdif cable to the receiver, because rx-v365 doesn't support audio via HDMI. If BD player has only optical output, use DTV/CABL HDMI input and DTv/CABL Optical input on the receiver.
2helpful
I plugged in my cable HDMI into my RX - V365 Yamaha reciever. and HDMI into my TV. I get video, but cannot get my attached (to reciever) speakers to play. Help
RX-V365 doesn't support HDMI audio. You need to connect the cable box also via spdif cable for audio to work. Look at the box if it uses optical spdif or coax spdif. If optical, you see that optical input on receiver is named DTV/CATV, so use also DTV HDMI for video. Coax spdif is named DVD, so in this case you will need to use DVD HDMI input.
Also you need to configure the inputs accordingly.
3helpful
2answers
I own a Yamaha RX-v365 and i cant figure out how to connect my PS3 to the surround sound. For some reason the HDMI cables wont work. Any help would be greatly appreciated. Thanks
As above :
Connect PS3 via HDMI to DTV/IN, Connect HDMI from out to TV's HDMI/IN. Connect TV's Optical out to amps DTV/Optical in.
2X HDMI cables and one Optical are required.
I have the V363 but yours looks the same.
Enjoy great sound :)
OH: choose the DTV input then stereo and then dolby etc .. cheers
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
