I have a Whirlpool side-by-side refrigerator model #ED5FHGXKQ02 with an Ultra Ease Water Filtration System. After we moved, the doors no longer lined up straight. How do I adjust them to be straight again? Also, the water dispenser in the door now drips constantly.
The refrigerator door does not stay shut
I would suggest that you get a certified person to come out and look at it you very well could have bent the doors in the move.
but... if you want to do it yourself.
click here for a walkthrough
for your drip:
Flush air from the water system the first time it is used and after
replacing the filter. Air trapped in the water line or filter may
slowly travel through the coiled water reservoir to the dispenser,
pushing any water ahead of it. This can cause the dispenser to
drip. Water needs to completely fill the lines for all air to be
cleared.
One
or two drops of water immediately after dispensing is normal. It may be
necessary to hold the container under the dispenser for 2 to 3 seconds
after releasing the dispenser lever.
Hi, Josh,
The dripping solution worked for a while but the next time the water dispenser lever was bumped, the dripping started again. The step-by-step solution for the doors, however were for a different problem. My side-by-side doors are rubbing together at the top where they close and are angled wide apart at the bottom and I couldn't find any way to adjust them.
