I have the Sony STR DE 575 receiver and I am trying to connect my Wii into the system to utilize the surround sound. My Wii has the AV jack (red, yellow, white) rca jacks. How do I do this with the satelite as my main signal hooked up. My VCR no longer has video with the new Satelite connection coming from the cable hook up I use to have.DVD player works fine, Satellite TV works fine. Just cant use the 3 plug input on the VCR to take advantage of the surround sound. Most of the input connections only have two connections, red and white, no yellow for video. How do I make this work. Use the S-Video for all the devices, feeding into the TV???? Help
Connect the Wii to your television. Then connect the variable audio output from the TV to the audio in on the monitor section of the receiver. Then use the TV/SAT input selection on the receiver and dolby prologic 2 as your sound mode.
Testimonial: "You where right on the money, I did what you said and it worked. You are the man!"
Well, I hooked the Wii directly into my old 42 inch TV Audio input jack and then ran the two rca jacks out from the audio (from the TV) to my Sony amp, connecting to the input section of the monitor section. I then changed the Wii sound selection to surround sound, made sure that my Sony STR DE 575 was using the Dolby Prologic. One more step, I had to tell the TV itself to turn off the internal speakers and use the variable output. WALA, it works. What a piece of work! So I played games for hours, smiling like a chesser cat doing so.. Thanks for your help.
